![]() | Home > Maintenance & Mods (L322) > Observations after Transmission service |
doclees Member Since: 25 Jun 2015 Location: PA Posts: 672 ![]() ![]() ![]() |
I have about 5k miles since last drain and fill. Fluid still a bit dark but its feel and smell is very close to new fluid. Transmission just gets smoother. I may change the filter again in another 5k miles. It takes just about 3.7 L . I changed the filler and drain plugs the first time but not since and not had any leaks.
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Getting better then mate |
I'd say the cleaner you keep it the better. There is an excellent YouTube video explaining the flush vs drain and pros and cons of the flush on a very dirty transmission. |
Hows doclees going?
Yes time for me to drain/fill a last time with Febi before I do the filter and go to Pentosin. Still runs better all the time. I'll be happier when a get a lower temp thermostat too. |
For sure on the stat.
Hadnt thought of inclining the FF, keeping in mind the drain plug location (its at the front of pan), perhaps if the pan was off it might help. |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1014 ![]() ![]() |
The shape of the torque converter is such that inclining it by a few degrees isn’t going to make a lot of difference to how much fluid you can get out
Even when you have the torque converter on a bench and can turn it through any angle you like, it’s still impossible to get all of the fluid out of it. I have a brand new one in stock (i.e. completely dry) so I’ll have a go at measuring exactly how much fluid it takes to get it up to this minimum level.
Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 ![]() ![]() ![]() |
Oh well, never mind, just a thought. Strangely, I can hear the voice of Homer Simpson saying: "Doh! Great plan, Bart!" |
Update: Last drain and fill with Febi brand. Will be using Pentosin unless the cost has gone up. No pictures. Still dark but a shade lighter than last time and smells very much like fresh fluid. Transmission has continued to shift even smoother when searching for gears in downshifting for hills. There was about 10k miles from the last change. Next change will include a new filter.
Another update: 165k miles now. I was going to do a filter drain and fill but my gasket was torn so just another drain and fill. This time with Pentosin. I had been getting the slightest sort of rare inconsistent noise primary in 5th with low rpms going up hills before a downshift. Sounded like the air pump coming on for a second or two. See what you hear when your radio is dead and you are a bit paranoid.
Pawl Member Since: 08 Nov 2017 Location: West Midlands Posts: 709 ![]() ![]() ![]() |
Seems to be a big difference in what comes out of the 6 speed ZF transmission when drained vs earlier GM 5 speed.
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Would tc change be cheaper and more comfortable at first?? 2010 3.6tdv8 180k km.
Are you asking if pulling the transmission and replacing the. Torque converter would be easier? Not for me. With the Pentosin things seem even better. I can't say like new shifting because I never had one new. But shifting would sometimes upshift too soon going up a hill and then need to down shift again. Not anymore. Fluid costs me about $10 US or less per litre. |
