![]() | Home > Technical (L322) > Water ingress and trim removal - updated with pic |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
According to RAVE, you have to remove the upper trim, (remove sufficient aperture seal - rubber door seal). which is apparently clipped in This reveals two torx screws holding the lower trim in place. John
Zain Member Since: 17 Apr 2014 Location: London Posts: 98 ![]() ![]() ![]() |
Thanks for the quick reply John.......do you have the link to the rave section dealing with this? The problem is the very tight fit of this trim even with the door seal slightly peeled back.....cant get anything in there. Reluctant to be brutal because of the close proximity of the airbag. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
RAVE download links are in the wiki.. ... - .- -.
You can disable the airbags to give you peace of mind.
Ah was kinda hoping to avoid disconnecting the battery......usually leads to electrical gremlins on re connection.
UPDATED with pic
Roverlord Member Since: 20 Aug 2016 Location: london Posts: 29 ![]() ![]() ![]() |
what is the purpose of the square clip? |
Seems to be a push fit retaining clip; holding the large white corner bracket to the black metal sunroof frame.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
"Just need a torrent of rain now to see if the drainage channel in the sunroof frame is clear enough to clear the water without spilling over outside its intended route."
Unfortunately no access to a hose pipe im afraid. Have a emptied a few water bottles over the closed sunroof and it remains dry inside but i guess the true litmus test is a heavenly downpour. |
Beg steal or borrow a watering can, failing that invest in one! for a kick off it will hold 10 litres and with the rose attached will emulate rain rather well.
