![]() | Home > Technical (L322) > Windscreen Washer Fluid Level |
Just a quick warning to check the level of your Windscreen Washer Fluid as if its nearly empty (or empty) the fluid can run back out of the pipes leaving them "Non primed" and allowing the pipes and nozzles to freeze. Once frozen they are very difficult to defrost with the temperature below freezing making driving on salted roads impossible.
The nozzles themselves are heated, and the system has a 1 way valve in so the tubes should drain back into the tank... However if you dont use anti-freeze in there then the 1 way valves get damaged and as you say all the fluid will drain out of the lines... |
No this is 42000 fsh unmolested original Vogue in beautiful condition in Silver/Jet/Burr-Walnut. Very pleased with it. ![]() |
Thanks Dan I did not know the technical reason but as the tank was dry and the system did not work after refilling I figured "frozen" as the car was covered in deep snow when I collected it. It started working after poured warm water on nozzles and I hand massaged the tubes after refilling it with Screen wash. Perfect now ![]() |
Most screenwash is barely frost proof, the stuff you buy in the petrol stations is generally only good for -5, and even then there is a considerable amount of "slush" in the fluid that will block the pickup filter.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35776 ![]() ![]() |
mine tells me when its low on washer water... |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
So far my ingenious mix of water and meguiars hyper wash car shampoo has worked a treat, no smearing, hasn't froze up at all and makes for some interesting frozen bubbles. 2006 Mercedes CLS
Yes they all do Scarey but this one was at a dealership and they could not be arsed! |
Sportex Member Since: 12 Jun 2010 Location: Up North Posts: 366 ![]() ![]() ![]() |
as my washer bottle has no bumper in front of it, it is permanently frozen solid |
GJOB Member Since: 24 Oct 2010 Location: Northants Posts: 131 ![]() ![]() |
Heated you say? Mine are hit and miss in this weather even with a full bottle of screenwash in it.... Anyway to test if they're operating as intended? |
As a cost of around £6.00 I would nust replace them anyway. I supose you could measure the resistance or something?
Thanks dan, i'll save this link and will try and confirm if they're busted first. Cars going in for a MOT next week so will add this to the list ![]() |
Still can only get one washer jet to work , drivers side just not working at all have tried the guitar string method , the compressed air method ............ Nowt |
