![]() | Home > Technical (L322) > 4 post lifts, and handbrake adjustment |
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 ![]() ![]() |
I need to change a couple of bushings on the rear (mot failure) and my mechanic has asked is it ok to use the 4 post lift or is there any procedure to watch out for with the suspension "hanging" - I never thought of it before as all I ever had done was a wheel change (and they used a large trolley jack for that) also the handbrake is weak (failed at 15% pass is 16%) I'll do a quick search now but any advice or tips would be welcome |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35805 ![]() ![]() |
craig put my SC up on a four poster without any problems.. ... - .- -.
berkshirelad Member Since: 06 Apr 2016 Location: Newbury Posts: 265 ![]() ![]() ![]() |
Unnecessary quote removed
zarnd Member Since: 22 May 2014 Location: Kent Posts: 459 ![]() ![]() ![]() |
Have had mine up on one lots of times Alex
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3270 ![]() ![]() ![]() |
Perhaps the OP's mechanic was asking about a 2 post lift? Hence the reference to "the suspension hanging" |
yes sorry I meant a 2 post lift the one that has the 4 arms that go out under the chassis |
My 07 VSE was put up on a 2 post lift. I drained the air from the suspension completely using the IID tool before it went up so as not to risk popping the airbags. I never had any issues caused by doing this.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8751 ![]() ![]() ![]() |
Mines been on one dozens and dozens of times... when let down it sometimes does some strange things but it's never been a problem, within seconds it's sorted itself out... No need to do any prep.... |
Big Boy R44ROV Member Since: 14 Nov 2011 Location: Chadderton, Oldham Posts: 556 ![]() ![]() |
I've had mine on 2 and 4 post ramps with the wheels hanging in the air with no problems at all. They are designed to do that with the ETC when a wheel leaves the ground or cross axles. No problem at all. I wouldn't worry too much about that. Tony
I don't have the fail sheet here but I think it was the near side lower rear hub (or something like that) |
If it's lower hub bushes then they will need a very substantial bush puller to do the job, if they are not used to working on big 4x4's they may not realise the ones they have for cars just won't work..
Cheers - I was thinking of telling him to get them anyway |
Mine has bee on 2 post ramps as well loads of times.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16395 ![]() ![]() ![]() |
That four poster was a two poster Stan ![]() ![]() ![]() |
