Home > Technical (L322) > Air suspension and HDC inactive after fitting track rod ends
Mac1971
United Kingdom 2004 Range Rover Vogue Td6 Giverny Green
Hi all, finally got round to changing track rod ends , tie rods and lower suspension arms. Steering wheel is slightly off centre so going in for tracking tomorrow , when I get above 20 mph the abs light , air suspension andHDC inactive faults light up. Is this common after track rod end replacement when wheel is off centre . What I am asking is am I worrying for nothing and will tracking sort this out. Cheers
Post #405930 22nd Sep 2016 7:17pm
If the steering wheel is too far off center it upsets all sorts... I expect it will be fine once the wheel is straight again... Thumbs Up Thumbs Up Pete
Post #405943 22nd Sep 2016 8:27pm
Mulcher
England 2006 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Would the steering reset procedure help in this case? This is where after starting the engine (don't drive forwards), you turn the steering wheel to full left lock and then to full right lock. 2006MY 4.2 SC
BMW R1250 GSA Rallye TE
Triumph Tiger 1050 (sold)
1979 Pontiac Trans Am (sold)
Post #405959 22nd Sep 2016 10:44pm
Steering angle sensor will be off possibly due to the tracking being incorrect, get it tracked up then do the go to lock thing.
If that doesnt work then a plug in reset should sort it. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #405960 22nd Sep 2016 10:51pm
Just FYI you can drive forward, back, anyway you like, turn left first or right... doesn't make any difference all it wants to see is the end of the lock both ways, and usually clears before that....
I do it reversing off the drive... Thumbs Up Pete
Post #405975 23rd Sep 2016 1:43am
As NMJ says, the steering angle is out and it will sort itself out once the tracking is done. Best have all 4 wheels done.
Post #405981 23rd Sep 2016 7:28am
Mulcher
haylands wrote:
just fyi you can drive forward, back, anyway you like . . .
thanks for clarification
haylands wrote:
i do it reversing off the drive... Thumbs Up
oooh, matron :d 2006MY 4.2 SC
Post #405985 23rd Sep 2016 9:06am
Mac1971
Tracking done today , all is good . Many thanks for the replys. Yet another learning curve 👍
Post #406065 23rd Sep 2016 5:00pm
