Home > Technical (L322) > All the lights and no speedo - first for me !
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Hi all, have done a search and cant find anything similar, so.....
Borrowed a flatbed today to pick up a vehicle, not sure if relevant or not. Arrived at destination, loaded up, turned it back on and I have a nice christmas tree, HDC. Susp Inactive,ABS etc etc. However and a first for me the speedo has stopped working, I assumed (wrongly) turn it off unplug trailer electrics and all will be good, unfortunately not Big Cry
Any bright ideas, thanks in advance Bow down
Post #406071 23rd Sep 2016 5:47pm
i wonder if you shorted something when plugging in the trailer electrics? ... - .- -.
Post #406072 23rd Sep 2016 5:57pm
Rosco
Thats my thoughts Stan, upon looking at them closely although it was a newish trailer there was a lot of gaffa tape around the plug, so hopefully just a fuse ( we can but hope ) Rolling with laughter
Post #406074 23rd Sep 2016 6:08pm
That will be the rear near side (passenger) ABS sensor, it runs the speedo and all the other things rely on a speed signal to work...
It will be well rusted in, I had to use an air powered die grinder on mine to get all the old one out, when fitting the new one don't use ANY force, it has to slide in nicely with no pressure or you will break it... Also be careful that you don't damage the reluctor ring..
I tried a pattern one as I couldn't get a genuine one when I needed it, it lasted a week... then fitted a genuine one... they even come with a little sachet of grease...
If your lucky it may have a dirty plug or have got pulled out, the plug is just behind the wheel arch liner at the back, around 3 o'clock on the wheel....
Thumbs Up Thumbs Up Pete
-Click here for Thread-
Post #406112 23rd Sep 2016 9:50pm
Rosco
Cheers Pete, will have a look today if it stops raining Thumbs Up
Post #406129 24th Sep 2016 7:19am
