Home > In Car Electronics (L322) > TV tuner "is what it is"?
johnb8538
United Kingdom 2014 Range Rover Autobiography SDV6 Fuji White
Just a quick question regards the quality of the tv tuner on a 2011 autobiography. On the move the reception is pretty much hit and miss. e.g maybe ten minutes fine then a two second freeze then a minute ok then another freeze then another minute and another freeze etc etc (you get the idea)
Is there any "fine tuning" or "regional retune" I'm missing. As far as I'm aware you set the country, the PAL selection and then the car auto tunes as you move around regionally. Most comments suggest the LR kits just aren't up to "tv in motion" as well as aftermarket kits. If there is an easy upgrade (without ripping the dash out) then give me a pointer please but otherwise"its just pants mate" would be a reasonable response. It works perfect stationary. Very Happy
Post #406154 24th Sep 2016 10:12am
digital tv wasnt really made for 'on the move' use as the signal fluctuates to much...with the old analogue signal you mostly got something on the screen where as the digital is either there or not...
obviously in strong signal areas you will get a picture but drive by a high building then even then the picture will disappear.. ... - .- -.
Post #406174 24th Sep 2016 3:32pm
johnb8538
Thanks Stan. As I thought and I'll just let it be.
Cheers.
Post #406241 24th Sep 2016 11:52pm
Only way for reliable TV in motion is to fit one of these
http://www.kvh.com/Leisure/Marine-Systems/Television.aspx
Whistle 2008 MY Supercharged
Post #406249 25th Sep 2016 4:37am
johnb8538
I don't think the other half catching up on her soaps is worth that much!!! Shocked
Post #406338 25th Sep 2016 4:30pm
