![]() | Home > Technical (L322) > Temp Bodge Repair For EAS compressor |
You taped up the piston itself, where the teflon ring sits, in order to prevent air passing through that gap, and not the piston bore? .
desertdude Member Since: 10 Sep 2016 Location: Dubai Posts: 60 ![]() ![]() ![]() |
I taped up the piston channel in between which the original seal sits, and then put back the worn out seal back on. So now its probably a little more flush with the bore.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35834 ![]() ![]() |
Edd China is an Oaf, he threw away a perfectly good steering box and replaces it with an expensive replacement on the Disco 1 episode because of some play, when there is a nut given on the top of the box to tighten in tiny increments to get rid of play as the worm gear wears away over the years. |
