![]() | Home > Technical (L322) > Strange noise on my 4.4 |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3246 ![]() ![]() ![]() |
Not certain but could be chains going (guides or the tensioner?) shot in the dark but worth checking? |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
When was the last oil change?
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
That's not a good sound from one of these, I started my timing chain guide preventative maintenance today to prevent them failing.
Clivefog Member Since: 23 Aug 2015 Location: Bristol Posts: 354 ![]() ![]() ![]() |
You can stop the viscous fan from turning. |
Having listened to my noise and yours, mine on idle is a lot faster but not entirely sure what that tells you, maybe because the water pump is geared by the pulleys making it turn faster, yours is in time with the revs.
mattyp Member Since: 30 Jul 2016 Location: Clacton On Sea, Essex Posts: 101 ![]() ![]() ![]() |
Thanks for the comments, I have looked through the history with the car and there is no sign of a water pump change. I had the car serviced last month and they removed the sump because it was leaking and there wasn't any plastic parts in there. I will remove the sump and have a look |
Check water pump first.
i think the high temperature that the engine is forced to run at doesn't help the plastic guides either hence the 80 deg mod is going in mine this week also. |
Absolutely, I did mine a few months ago, all I see is positives so far. |
got in from work and the rr is leaking coolant from the front of engine. There is a small puddle |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8765 ![]() ![]() ![]() |
Hmm, thinking the water pump idea might be along the right track.sounds like the shaft seals have gone and what you can hear is the bearings not liking being wet.... There is nothing that can't be fixed with a hammer😜😜
That could be very good news, mime wasn't leaking but it probably only a matter of time. make sure if it is you get a hella or Behr if you can as the cheap ones are useless i am told |
+1 for holidaychicken's advice
Right sump is off and look what is inside
