Home > Technical (L322) > IID tool codes
Roverlord
England 2003 Range Rover HSE Td6 Zambezi Silver
IID tool codes
I have these codes, anything to worry about?
what's this line maker thing?
ABS-Brake Module
• 0x5A Temporary system deactivation
EAS-Suspension
• 0x32 CAN bus Fault
ECM-Engine (DDE4)
• 0x2800 Unknown
• P0575-20 Speed control malfunction - speed signal failure
IP-Instrument Pack
• 0xBD EBV function fault received from ABS ECU
LCM-Light Control v11
• 0x57 Air suspension active/inactive
• 0x8E Right side marker defective
• 0x8F Left side marker defective
• 0x0094 Unknown
• 0x0095 Unknown
PATS-AntiTheft
• 0x3 Key 0 - Random code tolerance increased
TBOX-Transfer Case
• 0x5212 Battery undervoltage (0x5212)
• 0x5223 Noise on actuator signal (0x5223)
thanks in advance
Post #405977 23rd Sep 2016 6:32am
ABS-Brake Module
• 0x5A Temporary system deactivation Be an old code if they work now
EAS-Suspension
• 0x32 CAN bus Fault Standard fault no action needed
ECM-Engine (DDE4) Can't help mines a petrol
• 0x2800 Unknown
IP-Instrument Pack
• 0xBD EBV function fault received from ABS ECU Standard fault no action needed
• 0x57 Air suspension active/inactive Probably an old code again
• 0x8E Right side marker defective Standard fault no action needed
• 0x8F Left side marker defective Standard fault no action needed
• 0x0094 Unknown Standard fault no action needed
• 0x0095 Unknown Standard fault no action needed
PATS-AntiTheft
• 0x3 Key 0 - Random code tolerance increased Standard fault no action needed
TBOX-Transfer Case
• 0x5212 Battery undervoltage (0x5212) Standard fault no action needed
• 0x5223 Noise on actuator signal (0x5223) Standard fault no action needed, may indicate it's on it's way out but mines been doing this for nearly 3 years and still works fine Pete
Post #405988 23rd Sep 2016 9:18am
Roverlord
Thanks Pete.
Post #406001 23rd Sep 2016 10:37am
SteveMFr
Site Sponsor
Hi RL,
In situations like this, we generally advise to save the list (which you have obviously done) clear, and check again in the near future. Some fault codes bear investigation, others will show right back up again and have absolutely no effect. Especially with an older battery.
Cheers
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #406221 24th Sep 2016 9:47pm
RR2008HSE
Very helpful. The first time I used the IID, I found 27 faults and was pretty worried. GAP were great about 'clear and retest' followed but what faults can be safely ignored.
Post #406414 26th Sep 2016 12:56am
