![]() | Home > Maintenance & Mods (L322) > Does the 6hp26 have a built in thermostat for its oil? |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1005 ![]() ![]() |
As far as I know it works like the 5-speed system. All the transmission’s lubrication flow goes through the cooler all of the time and it’s the water side of the oil cooler which is controlled by a thermostat, depending upon the temperature of the coolant.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1502 ![]() ![]() |
Interesting, thanks Phil.
If I remember correctly the SCs have an additional engine oil cooler (driver side RHD cars) in front of the front wheel. That may be the reason the engine warm up is different.
Yes, mine has the radiator cooler on the rhs, which is why I temporarily disconnected the heater/cooler on the lhsas I knew I would still get engine cooling for the oil.
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Another cooler on that system would need to be on the return to transmission side of the flow, otherwise you create a push pull sort of situation. ie you are cooling the fluid only to have it re heated and I think the engine side of the equation is going to win that fight.
I think the coolant stat in the Jag engine is lower than the BMW systems. At a hunch its around 84degC from other forums. Although not definitive, i think thats about right from just the smell of the engine after being worked - it definitely doesn't smell as hot at the BMW unit used to when it ran with the higher temp state.
I think I like the idea of an air heat exchange.
Reading up a bit more, suggestion is that parallel is the better way. This is cause the flow from the heat source is halved across the coolers. With half flow the oil spend more time in the cooler being cooled. It also mean that both coolers get the highest temp fluid going to them. Heat transfer works faster where the temp differential is graeatest, so the hotter fluid each cooler gets the better transfer. So longer time in cooler and better temp differential is the way forward I think.
Use pipe work as much as possible, especially around any exhaust components, hose connections are fine at the ends.
Well there are short rubber sections near to the heat exchanger, and the run back to the box is metal pipe. If I tap the rubber, then I only have to run another rubber hose round the edge of the main radiator to the front area. Probably able to do it with about 12 to 18" of hose at most.
