Home > Technical (L322) > Wet front passenger side carpet - not sunroof leak
Zain
Not been my week for finding soggy bits - see my other post for water in the wheel well and amp area.
This ones slightly different. The front passenger side carpet is soaked through and the wetness feels slightly sticky and greasy to the touch. It's not related to the Sunroof drain as that is clear and free flowing. It's not coming through the bulkhead and windscreen cowl area as the slant in the footwell is completely dry, only the base of the footwell is wet. Upon taking off
the right hand side footwell trim (next to the glovebox) I've found the source of the leak - I'm assuming it's the O rings on the heater matrix pipes which have perished:
Can the O ring(s) be changed without taking the whole heater matrix and pipes out (which in itself involves hours of taking almost the whole front dash apart). I'm hoping someone's got a method of doing it with the pipes almost in the same position.
Post #406713 27th Sep 2016 11:03pm
Zain
Just bumpin this up ........hoping for some advice.
thanks
Post #407009 29th Sep 2016 6:39pm
mariner30
United Kingdom 2003 Range Rover SE Td6 Rimini Red
Did you ever get this fixed or even get an answer? 2003 TD6 SE model with EGR removed
2004 Jeep Grand Cherokee - drowned!
2002 Nissan X Trail - Passed away
1997 BMW E36 323i Conv. My spare for summer use!
Post #457447 15th Nov 2017 11:11pm
fisha
The greasiness you mention is typical for coolant, so yeah, I would agree with the thought that its the heater matrix.
On the old P38 range rover, you could change the o-rings with the matrix in situ IIRC. By the looks of that picture, it does appear that there is some space for the pipe to move outwards once you undo the clamp.
There is only one way to find out really! undo the clamp and pull it outwards! (after you have drained the system of course!)
Also might be worth checking that the pipes have some wiggle room ... are they clamped anywhere else, i.e. where they pass through the bulkhead or attached in the engine bay side. Loosening those areas might give you more play in the pipe. V8 or else ...
Post #457512 16th Nov 2017 2:16pm
Zain
Update : its still leaking sporadically.....not had the time to do anything car related as been away on work for the last few months. However its still on my list of a few things to do...... but the good news it did sail through its MOT last week with no advisories!
Post #458843 28th Nov 2017 5:50pm
Sandyt
I should imagine you can do insitu I had the trim off last week and if you disconnect pipes in the engine bay that should give you enough room Thumbs Up good luck
Post #458878 28th Nov 2017 9:25pm
