Home > Technical (L322) > Low Range or lack of it
Hi Guys,
Took the dog out for a walk before and on the way home though about low range and though i would give it a quick go. Now I've never used it in anger but do every now and again engage it just to make sure it works. Same today though i would just check its ok............nothing! no warning on the dash to say engage neutral, no lights no nothing. tried in every gear, brake on/off but nothing. Is there a fuse somewhere? looked in the glovebox but there wasn't a low range one. Its as if the switch isn't working? possible?
This isn't a big problem for me as its not likely to be needed, BUT if its there i want it to work!
Rob
Post #40708 3rd Dec 2010 4:43pm
Just to add now. Come out to pick my son up so thought I would try again sat on the drive and hay presto working! The light flashed for a while so was a bit slow to engage but a few times later an worked straight away. Any ideas? Not used enough?
Post #40718 3rd Dec 2010 5:35pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
blame it on the cold for it never to happen again... Wink 2004 black Vogue TD6
Post #40719 3rd Dec 2010 5:37pm
Possibly not being used enough
Post #40726 3rd Dec 2010 5:58pm
