Home > Technical (L322) > air suspension locked
reynolds
England 2004 Range Rover Autobiography Td6 Buckingham Blue
Any help please my 2004 range rover" air suspension inactive warning "has come on no speed warning also the suspension lock light has come on preventing adjusting it any advice much appreciated.
Post #40773 4th Dec 2010 10:16am
first thing i would check is the battery, if its over 3/4 years old it might be failing... ... - .- -.
Post #40793 4th Dec 2010 1:09pm
Start up and turn the wheel all the way to the left then all the way to the right and should clear the fault.
Post #40802 4th Dec 2010 1:24pm
reynolds
thanks for advice battery is 6 months old i have turned steering wheel lock to lock disconnected battery fault still there any more help much appreciated does any one no where the obd port is located on 2004 diesel autobiography
Post #40915 5th Dec 2010 12:54pm
obd port is on the lower right of the dash by the door. ... - .- -.
Post #40918 5th Dec 2010 1:09pm
dan_uk_1984
Same place it is on every L322. In the coin tray by your right hand knee when sat in the drivers seat...
I have one of these: http://www.rswsolutions.com/index.php?opti...;Itemid=77 and it's a lot of bang for your buck!
Post #40919 5th Dec 2010 1:15pm
reynolds
thanks for advice had it checked at garage pump nfg hope that cures it
Post #41275 7th Dec 2010 9:59am
Nickj
2003 Range Rover Vogue SE 4.4 V8 Java Black
Let us know if sorts it. having similar issues!!
Post #41499 8th Dec 2010 9:49pm
reynolds
yes all sorted
Post #41531 9th Dec 2010 12:53am
Nickj
How much was the pump and installation?? Did you have any issues raising/lowering the car prior to fault??
Post #42021 12th Dec 2010 7:18pm
reynolds
hi it cost just under £500 inc fitting and programing i was advised not to keep lowering and raising vehicle as it causes premature failure as car is very heavy for the size of pump
Post #42180 13th Dec 2010 5:30pm
letsavit2
United Kingdom 2004 Range Rover Vogue Td6 Java Black
£500..... Rolling Eyes £270 part. hours labour.
Hardest bit of the job is taking the spare wheel out. 2004 black Vogue TD6
Post #42193 13th Dec 2010 7:27pm
Fr_Raf
France 2004 Range Rover Vogue 4.4 V8 Java Black
I have had the "air suspension inactive" for few weeks.
I changed the battery as the voltage was under 12 volts when I had a look on board computer messages.
I tried to turn wheel from left to right without success.
Today, I received my EAS activate from RSW, I just plugged it and wait for blinking green led.
The air suspension inactive message disapear, and I can now use my suspension correctly
Post #43294 23rd Dec 2010 10:30am
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I'm still waiting on my EAS activate, left USA on the 29th November...Bloomin snow!!!
Hopefully will sort my car out, as having no HDC, ABS in this weather is a pain! Big Cry
Post #43297 23rd Dec 2010 11:11am
IanV8
Scotland 2011 Range Rover Vogue SE TDV8 Santorini Black
I have had similar messages recently after being in deep snow but they tend to clear after a while with an ignition off/on.
What I have noticed is that the speedo drops to zero at about the same time as the lights come on and this had me thinking that the problem is probably related to a speed sensor some where.
Have not looked further yet.
Ian
Post #43327 23rd Dec 2010 3:11pm
