![]() | Home > Technical (L322) > air suspension |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
RR P38 Member Since: 12 Oct 2013 Location: Sydney Posts: 215 ![]() ![]() ![]() |
Drive it up on the sleepers it will save your arm.
Remember that low mode is not the depressurised height, it will drop a few more inches... so err on the side of caution and get it high |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Great input again gents |
Never meant to post the |
From Rave 'System Description and Operation'
RP123 Member Since: 06 Jul 2014 Location: Highlands Posts: 187 ![]() ![]() ![]() |
Hi
Your an absolute star ! Parts enroute,pressures at 0.09 bar just now so should easily depressurize..going to attempt it in Saturday... |
Simon...yeah I've already tried that I'm afraid. |
Right I have been looking in to the "Pressure Static when filling " fault, and it seems to be a fancy term for the ecu hasn't a clue what's going on so I'll have a fit |
Was thinking that the valve block could be part of the problem...when I'm under it at the weekend I will check piping ect..do you think its worthwhile taking the existing valve block off and trying to clean it? Failing that island 4x4 have replacements and their not that expensive tbh...my friend basically gifted menthe car when he got his l405 so quite happy to spend money to get her in perfect working order..
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
I had the "Pressure Static when filling " fault , replaced the sensor in the reservoir, had the valve block on the reservoir apart,
Took delivery of a new one yesterday.. Never helped so now its investigation time |
