![]() | Home > Maintenance & Mods (L322) > What can go wrong next, timing guide failure this time |
mattyp Member Since: 30 Jul 2016 Location: Clacton On Sea, Essex Posts: 101 ![]() ![]() ![]() |
Looks like he don't have anymore, would you sell yours ? |
Covbandit Member Since: 11 Jan 2016 Location: Coventry Posts: 108 ![]() ![]() ![]() |
Sorry couldnt sell mine, but if you are quick
Thanks for the help, I have bought that kit. I love the way you don't have a clue these guides are going. I started mine up and the revs shot up to 2k and then dropped and it started making a ticking noises |
I must admit mine did have some warning, I just did not know it, there was a slight humming noise on the over run, sounded a bit like the ild radio zzzzzzzzzz noise, I assumed incorrectly it was an idler bearing or alternator bearing, but now I know. I am going to change the hydraulic tensioner every 20k or so as this seems to be theroot cause, the tensioner loses tension, the chain is a bit slack, slaps the plastic guides and breaks them, as mine werent worn, but the main v one was just a pile of bits. When you pull the main centre v shaped guide off there is a small metal disc behind with a tiny hole in, obviously some sort of oil restriction washer, this fell out of mine and luckily I spotted it, just be careful when removing and check it is there before re-assembly.
Thanks for the help, what is this washer ? |
The main V shaped guide in the block has an o ring at the bottom where it fits in the block. It is in that hole that mine had this washer. About the size of a 5pence piece with an approx 2mm hole in it. I will see if I can find a piccie somewhere. |
Thank you, I know what you mean, did you use a acoustic meter to set the cams up ? |
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
having done this repair job myself a couple of years ago, im just posting here, that mine is still running sweet and quiet.
