Home > Maintenance & Mods (L322) > '07 ventilated/cooled seats in and '02
Danwilderspin
Just wondered if this retrofit is possible? If so what is needed other than the seats? Will I have to uses the later heater panel and will that all work? I guess the. I'd need a home for the air suspension? Cheers
Post #407201 30th Sep 2016 11:13pm
No Dan, in simple terms... Everything is different from the electronics to the car floorpan... The 07> seats will not even bolt to the floor as the floorpan changed when the seats were equipt with airbags... Thumbs Up
Post #407205 1st Oct 2016 12:52am
Danwilderspin
Ok great what about from a 55plate ventilated seats - same problem? They look a bit newer than the ones I have
Post #407847 5th Oct 2016 9:42pm
At the rate you're going, you'd be cheaper buying a newer Vogue SE Thumbs Up Got - 2017 SDV8 Autobiography in Loire Blue
Post #407859 5th Oct 2016 10:55pm
Yes 06my seats will fit as they are the same fitment between 03-06my's Thumbs Up
Post #407872 6th Oct 2016 12:41am
Danwilderspin
Great - how about the controls for cooling?
Post #408005 6th Oct 2016 8:54pm
