![]() | Home > Off Topic - Other Cars > Diesel conversion for a Classic, which engine? |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8622 ![]() ![]() ![]() |
Fair comment... just a thought...
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
I will admit to looking at both D1/2's and Diesel Classic RR's and while they are a very useable as an every day car.. the 111 bhp - 123 bhp depending on which engine they have, isn't enough power for what I do... the Merc at 167bhp is border line underpowered and the ffrr at 177 isn't much better |
I'll saynit again, you need an F250 or Dodge Ram with LPG install if it's not a diesel
If you want a Disco1/2 and find or build one from a rot free tub and chassis then really for towing your limited to shoving in a 4bt/6bt with fuelling mods and turbo windup. There is a way to run a twin turbo setup on them for quicker pickup.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2617 ![]() ![]() |
The Cummins are very heavy - OM606 if you're set on something old. Correct answer is probably a modern US diesel pick-up to pull a genuine 3 1/2 tons all day though. |
Right there are good and bad reasons for this post, I'll try and address them so you've a better idea.....
johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035 ![]() ![]() ![]() |
Your quest might be so difficult, that it may just be easier to take a career change!
Have you considered a 4.2 SC on LPG ?? Plenty torque/BHP and a pretty strong gearbox (apart from the one solenoid issue and the coolers on the early models). If you get a later one 2007/2008/2009 the cooler issues should be solve (better coolers) and these models are not very expensive anymore and pretty bullet proof. MY 2010 5.0 SC Galway green and sand interior!!
I did look but they are TDV8 money.... so why not stick with a tractor to do a tractors job |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1570 ![]() ![]() |
ex-Australian Army Land Rover 6x6 Perentie. No rust, low km (I know a bloke who bought one with only 800 km on the clock), unburstable Isuzu 3.9 litre 4BD1-T Turbo. Also they have a wider body than a standard LR.
Miggit, forget about BHP, it's torque that does towing. When I drove wagons for a living I had many tug units, but chief among them was a Foden. Only 380 horsepower which isn't a lot for 38 tonnes - that's 10bhp per tonne by which reckoning you'd need less than 55 bhp.
