Home > Maintenance & Mods (L322) > has anyone ever mod'ed front indicators ?
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
has anyone seen, got, made an alternative front indicator's for the early l322 ? I guess that a ballast risitor would be needed for LED conversions but I cannot find for love nor money an alternative part anywhere
Post #408202 7th Oct 2016 8:32pm
pld118
Lukie, hopefully this thread will assist Thumbs Up
http://www.fullfatrr.com/forum/topic21661.html?highlight=led
Post #408210 7th Oct 2016 9:29pm
Lukie
Sadly my l322 is the earlier pre face lift with separate indicator
Post #408250 8th Oct 2016 9:02am
fisha
Generally as long as you get canbus led bulbs then there isn't a need for ballast resistors ( that I've found so far ) V8 or else ...
Post #408255 8th Oct 2016 9:57am
holidaychicken
I did a bit of modding to mine ...
I have an LED sidelight bulb also but doesn't show on the camera much
http://www.fullfatrr.com/forum/topic32130-30.html
Post #409377 15th Oct 2016 10:11am
Lukie
did verydisco Photoshop the last image with no amber inserts ?
looking into a few different thing's, brother in law is currently playing with vacuum forming may speak with him see if anything can be achieved
Post #411346 29th Oct 2016 11:09pm
holidaychicken
Yes last image is photoshopped, i did buy an old cluster and tried to open it up but i think the only way would be to use a mini circular saw on a dremel and cut it open but would need to keep it cool with water as the plastic just melted when i tried but i did use an abrasive wheel rather than a saw with teeth. i have seen a few write ups on the L405 conversion to the L322...
Post #411367 30th Oct 2016 8:15am
miggit
I'll save you some Big Cry
I thought that clear indicators would be a fantastic conversion on my ffrr.... I had a spare front light unit and a broken light unit, so I set upon them with a Stanley knife and removed the clear lens from one and the amber one from the other....I felt a swap coming on Mr. Green and then I found out that the amber lens is a different size to the clear one, D'OH!! I can't remember which is the smaller, but the end result is the clear side light lens wont fit in place of the amber lens Banging Head Banging Head Big Cry Yesterday I couldn't spell Engineer... Today I are one!
Post #411387 30th Oct 2016 11:05am
miggit
Found the little Censored 's
the clear one will sit over the amber :(
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Yesterday I couldn't spell Engineer... Today I are one!
Post #411389 30th Oct 2016 11:18am
holidaychicken
Do the lenses come out from the back then, i can't remember?
I bet i could make that white one fit where the orange one goes with a little modification and then just an orange bulb i guess ?
Post #411446 30th Oct 2016 6:39pm
miggit
Whistle It's rather involved to get at the blighter's.....
First cut / separate the clear outer lens, then you have to remove the chrome shell that is on top of the lens, and then if you haven't broken anything you can get at the amber / clear lens... the 2 chromed shells are not interchangeable Sad
The only way I can see of doing it is to cut the rim off the amber lens and then reduce the clear lens and bond it to the amber ring.... as the plastic is only 2mm thick I sort of decided that I would give up before it was all consigned to the bin Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #411518 31st Oct 2016 1:11am
holidaychicken
Blow that, i tried separating the outer cover when i looked into painting the internals black and opted to painting the outside instead.
I think if i had a stack of lenses to practice on I could devise a method but then again i could just live with the orange which i don't mind really
Post #411525 31st Oct 2016 7:44am
Lukie
They are a pain, look at most other cars including x5's you can get an array of after market lights Leds creeds fronts and backs, range rover pretty much nothing apart from side indicators Sad
Post #411567 31st Oct 2016 12:26pm
holidaychicken
I'll have to get the dremel out again when i run out of jobs to do...........
Post #411617 31st Oct 2016 8:02pm
