Home > Maintenance & Mods (L322) > AGM battery life
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
AGM battery life
I've had the AGM in my MY2011 since new. Not had any battery problems to date.
But do AGMs eventually die like lead acid batteries, or do they go on and on and on......[/b]
Post #408264 8th Oct 2016 10:43am
Hmb
England 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
I've had a few optimas. They just stop with no warning. 2010 Overfinch 3.6 V8 FFRR gone yee haa
2005 Supercharged 4.2 V8 FFRR (written off)
2007 RRSport v8 3.6
1996 300tdi Disco 1
Post #408271 8th Oct 2016 12:09pm
Ive replaced a few now but NO where near as many as the old type... So, seams to be a vast improvement Thumbs Up Bow down
Post #408279 8th Oct 2016 1:05pm
Dave
Are AGM batteries only for cars with Stop/Start tech? Dave
2012 Vogue Westminster 4.4
Post #408290 8th Oct 2016 1:42pm
mzplcg
No, a lot of the later diesel L322's had them from the factory.
Post #408292 8th Oct 2016 1:56pm
Biffo
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Sorry to be a thicko, but what benefit does an AGM battery give over "normal" ? When you say "not had any battery problems to date", do you still get "HDC Inactive" if you leave the car for a few days ?
Post #408294 8th Oct 2016 2:35pm
You only get that on pre 07my cars Biffo 👍
Post #408298 8th Oct 2016 2:45pm
Biffo
Oh Embarassed
Was hoping an AGM battery was the answer
Post #408302 8th Oct 2016 3:06pm
mzplcg
AGM is more aimed at leisure batteries. Instead of wet acid and lead plates it is made up of fibreglass mat which absorbs a gel version of the acid.
The advantages are that they can take a much deeper discharge and still come back to 100% from it. Also they can do this many more times than wet batteries before they fail. This is the main reason LR fitted them to the later L322s, to provide power for the fuel burning heater and still have enough to start the car.
As long as the CCA and AH values are similar the AGM is a much better technology. It tends to hold a higher voltage under cranking as well which is usually the cause of HDC errors etc on startup.
Post #408324 8th Oct 2016 5:54pm
Biffo
Thanks for the explanation Thumbs Up wish I'd been up to speed on this before I bought my battery a month or so ago Rolling Eyes Every day is a school day with my FFRR....
Post #408328 8th Oct 2016 6:52pm
