![]() | Home > In Car Electronics (L405) > Analogue clock |
So, first real grumble about the L405. Where is the analogue clock?
Emperor Mong Member Since: 07 Jul 2010 Location: London Posts: 1435 ![]() ![]() ![]() |
You can have one as a screen saver on the infotainment screen.
Anyone know what's behind the centre panel, below the AC controls?
Dixy Member Since: 09 Apr 2009 Location: Somerset Posts: 1108 ![]() ![]() |
Nothing important, get the Dewalt out and drill a 50mm hole. letters not necessarily in the right order |
You first, Dixy |
Been measuring up myself. Just need to figure out how to get the panel off and see what lurks behind. Of course, it does bring the issue of which clock to choose. There are so many tacky looking ones, or really old looking Smiths ones. The more prestigious ones (Aston Martin, Bentley etc) have the small matter of being integrated to the car and are adjusted by a signal from one of the ECUs. Even the L322 clock has that small problem so doubtful it could be integrated to the L405. EDIT. I quite like this one and it's only 30mm deep unlike the old Smiths ones. Shame about the tacky logo and the word "Clock" on the face. I'm sure even the most illiterate can figure out it's for telling the time. Jeez ![]() http://prosportgauges.com/12-volt-Premium-...White.aspx |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35728 ![]() ![]() |
.....and you have to find a live feed which then will flatten the battery... |
I would hope not Stan, a few milliamps at most. The display is off when the car's off so you shouldn't be able to measure the current draw in reality. |
Phil. Member Since: 19 Apr 2010 Location: West Midlands Posts: 792 ![]() ![]() ![]() |
Having a clock that kept time would be wonderful on a £100k mother. Mercedes manages it and their clocks auto adjust for BST. JLR are rubbish at clocks! MY23 D350 HSE
RR2008HSE Member Since: 06 Jan 2013 Location: British Columbia Posts: 2932 ![]() ![]() ![]() |
Disagree they're rubbish at clocks. Just looked at a 1994 RRC LWB for sale. Clock worked! Little else did.
Rob99 Member Since: 03 May 2016 Location: Gatwick Posts: 1469 ![]() ![]() |
Even my 11yr old Citroen had a clock which used the satnav to keep time accurately ![]() 2017 4.4 SDV8 Autobiography (2021-2024) - Santorini Black 2012 4.4 TDV8 Westminster (2016-2021) - Santorini Black |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16365 ![]() ![]() ![]() |
p38arover Member Since: 16 Dec 2015 Location: Western Sydney Posts: 1574 ![]() ![]() |
I dunno. My P38A VDO-made clock was always accurate. Could you fit a P38A clock? Ron B. VK2OTC 2003 L322 V8 Auto 2007 Yamaha XJR1300 Previous: 1983, 1986 RRC; 1995, 1996 P38A; 1995 Disco1; 1984 V8 County 110; Series IIA |
Well, funny you should mention that. What I've been looking into is how the thing gets adjusted. The L322 (and many others) use the screen to adjust the clock and then you can watch the hands whizz round magically to the right time. This is the main issue.
