![]() | Home > Off Topic - Other Cars > Diesel conversion for a Classic, which engine? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Your completely right about the torque..... but it's not just the torque alone, it's where the torque is delivered.... high low end torque is what's needed |
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2618 ![]() ![]() |
BT6 weighs over half a tonne, an OM606 is far more sensible approach. |
Agreed. That was the engine which took Otto to almost every country in the world.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
I tow our digger on a flatbed which is 3.5 tonnes all up, and it's the same with the D4. Start in low range if you have a slight slope it's what the manual says too.
also dont forget what ever you get you will have to have a tacho fitted to the tow car. There is nothing that can't be fixed with a hammer😜😜
How the |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
You only need your brakes on under 10ish MPH |
Low range - get the car rolling. Into neutral, change low to high, back in D and away you go. They all do it AFAIK |
Im also in favour of a D3/4 manual... Great tow cars and NO crappy auto box to constantly worry you |
Well I've been doing a bit of digging on the wonder web with regards to fitting a Mercedes OM606 engine in to a Classic, and giving it a little boost |
yep just like that in the FF, get rolling in Low, knock it into neutral, then into high, then back into D.
chex Member Since: 17 Sep 2012 Location: E. Africa Posts: 130 ![]() ![]() |
Do you know who does the conversions? 2004 L322 V8 |
chex, I have no idea who does these conversions |
