![]() | Home > Technical (L322) > Help required - TD6 wont start |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7964 ![]() ![]() ![]() |
Not an expert here.... on my TD6, when my in line pump failed the AA man too the pipe off the fuel filter whilst I turned the key. That proved whether fuel was getting to the front. Would that not show if it's one of the pumps or nor?
Bungy Member Since: 23 Jul 2014 Location: Dorset Posts: 7 ![]() ![]() |
It was sudden, we had just stopped at some services and then a mile down the road it cut out with a fuel injection system error. I had 1/4 tank and it went to the garage for the fuel filter and pump.
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
You should be able to hear if the in tank fuel pump is working as it'll prime for a few seconds with the ignition on.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
^what he said |
Thanks for the replies. I'll get onto that tonight and see how she does |
Just tried the relay and that works as I can hear the in line pump stop, next thing to try is the wiring for the in tank pump and the pump itself. Definitely not hearing any noisy coming from the tank area. |
Most common failure is the fuel pump just in front of the near side rear wheel. Remove the cover and with the ignition on hit the pump with a spanner or light hammer
It lives!
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
Any chance of a link for the pump that you used? Yesterday I couldn't spell Engineer... Today I are one!
