Home > Maintenance & Mods (L322) > Rear wheel bearing
Rear wheel bearing
Has anyone replaced a rear wheel bearing at all?
It looks to me like you push the inner splined section out(which also has the wheel backing plate on it) then push the bearing from the hub, then push the bearing onto the wheel backing plate, then push the backing play onto the front of the frontnof the hub.
It looks like fun but might pop by he specialist tomorrow and wave £10 in front of them if insteuggle at the local all makes garage as they have a 20ton press and I know the local specialist are a bit iffy about doing such jobs Sad FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #408489 9th Oct 2016 5:43pm
Weegie
Does this point in the right direction? http://www.fullfatrr.com/forum/topic39395.html John
GAP iiD BT-Sold
Post #408491 9th Oct 2016 5:50pm
Kind of weegie Smile
I'm sure in my kit I have the right sized spacer/press to force the hub out and then force the bearing off the arm but I'm but sure it will come off that easy without the faff of a three pronged puller/grip.
I suppose if I get it out of the arm I can always use a 1mm cutting disc to get the old one off and then just a press to get the new one on...
Might have to document the process FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #408499 9th Oct 2016 6:28pm
I tried to get the hub out of the carrier on the rear... took whole hub off, 20ton press, pumped it to about 23tons... didn't move a mm....
Might have had a dodgy hub but be prepared for a fight.... Thumbs Up Pete
Post #408535 9th Oct 2016 9:02pm
Great Sad
Might try a bit of heat on it after I remove the abs sensor to protect it from the heat I may end up using.
Hopefully if I can get the hub wheelplate pushed out of the bearing first then it will make half the job easier Smile
Where there's a will there's a way Very Happy well I hope it stays true!! FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #408549 9th Oct 2016 9:30pm
If you get the sensor out, I bet it breaks, or the wire pulls off it, last one I changed took a die grinder to get it out... Big Cry Pete
Post #408570 9th Oct 2016 11:12pm
Even more good news lol
Best start soaking it in the morning and just take my time with it Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #408574 9th Oct 2016 11:29pm
Needs a hydraulic press to push it out, not a DIY job
Post #408583 10th Oct 2016 4:30am
sako243
Some of us have hydraulic presses, Wink
Unfortunately I'm not one of them Crying or Very sad
Although plenty of box section and the formations of a plan... Ed
Post #408676 10th Oct 2016 7:45pm
Well it's done!
Tried a local hydraulic press but it just wouldn't fit.
Hate that it defeated me but for the time I would have spent fancying around with it and what the local LR specialist charged me to do it in happy enough.
Dropped it at 1, picked up at 5 and cost £30. Forgot to take a pic but the bits they have for doing it are like a puller and a press! Quite good I thought Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #408812 11th Oct 2016 5:58pm
