![]() | Home > Technical (L322) > Range Rover 2003 Torque Converter |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8578 ![]() ![]() ![]() |
The TC stays full of oil and it won't drain... Only half the oil comes out on a change....
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
When I did my TD6 with the GM5L40E gearbox, I first dropped the sump and cleaned it out and changed the filter... this got about 4 litres out.
Buff Rio Member Since: 29 Dec 2012 Location: Banstead Posts: 36 ![]() ![]() ![]() |
Thanks Miggit
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3267 ![]() ![]() ![]() |
Just to add.
Well it's good to know that it can be done |
It should be "RHD". As in England, Japan, South Africa, Republic of Ireland etc (not forgetting Scotland, Wales and Northern Ireland). |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1003 ![]() ![]() |
Just to clarify, on the 5HP24 the hot oil leaves the transmission from the port on the LH side of the casing (i.e. the pipe with the banjo bolt) and returns from the cooler through the port on the RH side of the casing (i.e. the one at the front facing forwards)
Phil (Edit - Oil cooler removed from diagram to avoid ambiguity) Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() Last edited by RRPhil on 10th Oct 2016 3:32pm. Edited 1 time in total |
Yes, rather unfortunately, RAVE contradicts itself regarding the cooler connections
So the banjo bolt is the feed and the straight coupling is the return.... which is easier to connect to a hose to dump the fluid in to your measuring container |
Update
I have the GM box so May have a difference but I would suspect from above that your levels were low.
Level will be very low, usually get a couple of ltrs down your arm if you remove the filler with the engine off... Pete
