![]() | Home > In Car Electronics (L322) > Fuse for analogue clock |
Lukie Member Since: 27 Sep 2016 Location: Liverpool Posts: 433 ![]() ![]() |
as far as I know the analog clock is set by the radio if the radio has been removed then the clock can not set a time |
Brian Member Since: 06 Dec 2014 Location: Northern Ireland Posts: 138 ![]() ![]() |
When you pull the fuse for the clock it resets back to 12 - so do it at 12 noon or 12 midnight and your clock will then be right. I don't know were the fuse is myself and never really bothered to look for it as the time is displayed on my aftermarket head unit. Also I keep forgetting about it until its after 12 |
UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 835 ![]() ![]() ![]() |
I think the analogue clock is set by the original radio, and if you've removed it the clock will start at 12 and run as normal for as long as the ignition is on, after that it will just reset to 12 every time.
Darren9330 Member Since: 02 Jan 2016 Location: Isle of Wight Posts: 10 ![]() ![]() ![]() |
Cheers,
not my project but there maybe a fix for this soon for all aftermarket unit's that can no longer set the clock, i will let the owner of the project know about this thread so please keep checking from time to time |
Thanks Lukie, much appreciated |
