![]() | Home > Technical (L322) > Coolant leak ?? |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Please fill in your profile so we know what car you have |
Stew 46 Member Since: 23 Feb 2016 Location: North cornwall Posts: 123 ![]() ![]() ![]() |
Profile sorted |
holidaychicken Member Since: 06 Nov 2013 Location: Kent Posts: 1086 ![]() ![]() ![]() |
Am I missing something here when it comes to what vehicle ? |
It's a 07 vogue SE |
@ holidaychicken
Well at least we know but my knowledge runs out at 2005, sorry ...
It's a 3.6 tdv8 |
mr_spock Member Since: 07 Apr 2016 Location: Welwyn, Hertfordshire Posts: 311 ![]() ![]() ![]() |
I'd start with the radiator. Mine had leaked, but there was little visible evidence until I unbolted the fan shroud, eased it back and looked down the rad with a torch. Then it was obvious. Then I'd check the expansion tank, as these split. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
Stew, as above... Rads leak, expansion tanks & caps and also the back of the engine oil cooler (the aluminium block under the oil filter cartridge) they have a habit of leaking on the firewall side through the pipework... Pop the engine cover off and closely inspect using a good torch, any staining inspect further pal |
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Ive read thermostat housing can crack. It could have happened to mine, as service history lists a replacement being fitted by previous owner.
