Home > Technical (L322) > Dead Battery
Steve French
United Kingdom 2004 Range Rover Vogue 4.4 V8 Zambezi Silver
Dead Battery
My 2004 L322 Vogue overheated in France and arrived back in the UK (after 5 weeks in France) on Monday afternoon and was dropped off at the garage for me.
My garage currently cannot get into the car to charge the battery because the car is dead and the key will not work because the battery is so flat ?
Help !
Post #408978 12th Oct 2016 12:39pm
Hmb
England 2006 Range Rover Supercharged 4.2 SC V8 Cairns Blue
http://www.fullfatrr.com/forum/topic38460.html 2010 Overfinch 3.6 V8 FFRR gone yee haa
2005 Supercharged 4.2 V8 FFRR (written off)
2007 RRSport v8 3.6
1996 300tdi Disco 1
Post #408988 12th Oct 2016 1:06pm
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Won't the key physically work in the lock? ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #408996 12th Oct 2016 1:30pm
^ that's a good point Thumbs Up ... - .- -.
Post #409008 12th Oct 2016 1:45pm
Weejock
2002 Range Rover Vogue 4.4 V8 Epsom Green
If it's a 2004 model then the key should physically work in the drivers door...unless the linkage has become disconnected internally. Unfortunately it's a common problem that people only find out about when the battery goes flat.
If it has a Tow pack then it can be charged up or a supply attached via the electrical socket, otherwise it's a case of breaking in.
Post #409163 13th Oct 2016 4:36pm
Hmb
Not quite. There is a couple of other ways. One is to get a live feed to the starter motor 2010 Overfinch 3.6 V8 FFRR gone yee haa
2007 RRSport v8 3.6
1996 300tdi Disco 1
Post #409173 13th Oct 2016 6:31pm
UK Marine
Bit difficult if he can't get in to open the bonnet........ Mr. Green ______________________________
Simon
Post #409190 13th Oct 2016 8:01pm
Hmb
Jack it up and go underneath. 2010 Overfinch 3.6 V8 FFRR gone yee haa
2007 RRSport v8 3.6
1996 300tdi Disco 1
Post #409192 13th Oct 2016 8:02pm
UK Marine
True but my commando days are over Rolling with laughter ______________________________
Simon
Post #409195 13th Oct 2016 8:07pm
Hmb
Why go commando?? Even in the army we had reme and the op's post said it was at the garage. Sure they'll have an easy way of lifting it off the floor.
There is a rumour that by removing a side repeater there is a live feed there also. 2010 Overfinch 3.6 V8 FFRR gone yee haa
2007 RRSport v8 3.6
1996 300tdi Disco 1
Post #409196 13th Oct 2016 8:10pm
UK Marine
Mines on the drive and it's dark and wet, just brought back many memories. I didn't read that it was at a workshop, my bad. ______________________________
Simon
Post #409201 13th Oct 2016 8:30pm
Hmb
Try the side repeater bit. The fil got into his daughters one like that. 2010 Overfinch 3.6 V8 FFRR gone yee haa
2007 RRSport v8 3.6
1996 300tdi Disco 1
Post #409202 13th Oct 2016 8:33pm
pembsRR
Clearly there's a good reason yours has gone flat in this case, however as a general rule, I think it's smart to change the battery at least every 3 y - there are so many reports of problems caused by low voltage, it seems to be to be fairly cheap preventative maintenance
Post #409228 14th Oct 2016 6:13am
