Home > Technical (L322) > Range Rover 2003 Petrol Air Suspension Inactive
Page 3 of 6 <123456>
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
Haylands wrote:
If you're going to keep the FF for any length of time it is well worth it, they always have a good resale value as well, so over it's life with you, it's cheap.....
the IIDTool is that not 1 range rover only locked ? sorry read the rest of the thread
while we are on the subject of diagnostics, I do incar diagnostics using the latest autel machine I did have hawkeye for p38 / l322 until recently (sod's law)
I also do LPG diagnostics can plug into most after market systems based in liverpool travel to stoke on trent, I can travel within reason
feel free to PM or start new thread for help, admin if not allowed I will happily remove just trying to help fellow FF's
Post #408871 11th Oct 2016 9:25pm
Vanhoolt8
United Kingdom 2005 Range Rover Autobiography 4.4 V8 Cairns Blue
Hi luke my 2005 L322 4.4v8 has got suspension inactive and HDC inactive on the dash if I leave it overnight it goes off until I go down the road 100yds and they come back on with the ABS light, I have put my code reader on a carsoft 930 and in ABS it says precharge pump and precharge pump pressure sensor I have fitted a new pump and it is no different I have checked the plug on the precharge pump and I have got no power does the power come off the ABS block the switch in the baxk of it the faults will not clear
Post #408880 11th Oct 2016 9:42pm
Do you offer this service for free or do you charge..???
FYI latest BT IID tool will read and clear faults on any JLR product that they cover (which is most from 2007 and some earlier) It is VIN locked for CCF editing only... It actually does more than the dedicated JLR one, and certainly more than any other tool out there, the back up and support is second to none as well... Pete
Post #408933 12th Oct 2016 7:38am
Vanhoolt8, more info here on your problem...
http://www.meeknet.co.uk/e38/ABS/Index.htm Pete
Post #408934 12th Oct 2016 7:47am
Vanhoolt8
Hi Pete just bled the new pre charge pump like the link you sent me all was OK in the drive went for a run below 30MPH no problem as soon as I went up to 30 steadily all lights for suspension and orange ABS lights so I have removed the black box off the ABS block and see if I can get it repaired or pick another one up and try that, I will let you know if that cures it, Many thanks for your help keep my fingers crossed cheers Nigel
Post #408971 12th Oct 2016 11:31am
UK Marine
England 2003 Range Rover Vogue 4.4 V8 Zambezi Silver
Hi Vanhoolt8,
My 2003 v8 also displayed air suspension and HDC faults along with a trans fail fault while in park, this was all down to the voltage output of my alternator.
These cars are very sensitive when it comes to voltage and the common faults that pop up are ABS, air suspension and HDC, so I would check the output from your alternator, it needs to be in the region of 14.0v to 14.5v or you will get faults. I was getting faults while idling on the drive while I was bleeding the coolant system, I would leave it overnight and they would disappear but when I took it for a run one night to bleed it through thoroughly I put my foot down and got the same faults again. This was explained to me that as the revs increased the pressure placed on the alternator wasn't reciprocated by its output and the battery had to step up and supply the voltage needed, this of course couldn't last very long and when the battery voltage dropped to 12.4v or so the faults appeared.
The faults tend to cascade as well, so if you get an abs fault that will cascade to HDC and air suspension.
I replaced my alternator and so far (touch wood) the faults haven't reappeared.
Regards ______________________________
Simon
Range Rover Classic 3.5 efi - Gone
Range Rover Classic 3.9 efi - Gone
Range Rover Classic 4.2 LSE - Sadly gone
Land Rover 110 3.5 - Gone
Range Rover P38a 4.0 SE - Pleased it's gone
Range Rover P38a 2.5 DHSE - Just sold
Range Rover L322 4.4 v8 Petrol - Current
Post #408974 12th Oct 2016 12:19pm
Vanhoolt8
Thank you Simon for that when I put my code reader on it says I have a fault on the pre charge pump and the pre charge pressure sensor and they will not clear, When I left the car overnight last night this morning I went out to it and bled the pre charge pump after doing this the internet says run steadily for a few mile and then increase speed gradually and all light and warnings should go so I went out and stayed at 20MPH for a few mile and all was fine as soon as I went up to 30MPH all ABS and suspension and HDC came on again, So I have an ABS pump coming tomorrow when I have fitted this if all is well I will let you know Keep fingers crossed If not then I will look at the alternator Once again thanks Nigel
Post #409003 12th Oct 2016 1:37pm
UK Marine
Hi,
What diagnostics are you using? I ask because if it's not LR specific it may be interpreting the faults incorrectly.
Have a look at the alternator output it's only a 2 minute job Thumbs Up
Simon
Post #409009 12th Oct 2016 1:46pm
Vanhoolt8
Hi Simon I am using a Carsoft i930 specially for Land Rover and Jaguar
Post #409014 12th Oct 2016 1:55pm
UK Marine
Hi Nigel,
Ah well worth a try. Good luck with the abs swap out.
Simon
Post #409016 12th Oct 2016 1:57pm
Vanhoolt8
Cheers mate I will keep you posted thanks Nigel
Post #409019 12th Oct 2016 2:15pm
Low voltage will trip all sorts of faults but not usually the ones Vanhoolt8 has, they tend to be less specific general faults, Vanhoolt8's speed specific faults are a known issue with the BMW braking system and is pretty well documented... Thumbs Up
Totally agree that the first and cheapest thing to do is check your voltage when ANY fault appears though... Thumbs Up Pete
Post #409023 12th Oct 2016 2:47pm
Vanhoolt8
Hi gentlemen i have just put another ABS Black box on the ABS pump and now i am getting faults OXOO8A air suspension system CAN error OXOO5A Temporary system deactivate and OXOO61 Steering angle sensor initialisation and HDC Inactive is still on air suspension inactive is still on and ABS lights are still on can anyone help as i am fed up with this now every time i change something i get different faults but no cure Thanks Nigel
Post #409660 17th Oct 2016 8:18pm
UK Marine
Hi Nigel,
Have you done the turn the steering wheel fully left and right to initialise the steering?
Also did you buy another ABS module or refurbish your own?
I ask because I'm sure a replacement ABS module will need coding to your car and that could be the reason the faults are there.
Simon
Post #409668 17th Oct 2016 8:54pm
Vanhoolt8
Hi Simon yes i tried the steering left to right and no different I have pu another ABS module on with the same numbers on as the old one and it came off a 2005 same year as mine so will that need re coding Cheers Nigel
Post #409684 17th Oct 2016 10:08pm
