Home > Technical (L322) > Range Rover 2003 Torque Converter
Page 3 of 3 <123
miggit
Wot they both said, with the engine running the oil is pumped around the gearbox filling things like the torque converter... with it off the torque converter half empties it's self... bearing in mind that the final level is to the filler plug with the engine on... when the engine / pump are turned off the level in the sump will go well over the filler plug Thumbs Up
Also have you checked that you are on perfectly level ground... my drive has a very slight fall to one side, about 3" over 6 feet, so not much... but it can make a 1.5 litre difference on the dipstick Shocked I have to be very careful cos depending on which way I'm facing it is possible to overfill or under.... The Gearbox is desinged to be done on a ramp, which are level.. or they'd run the risk of pulling out the ground (2 poster). Now while it is more than possible to do the gearbox oil without the use of a ramp, it is very important to get the car as level as possible.. I used some scaffold boards as packers, had to run the car up and down them a few times adjusting it to level... and then I discovered that by placing my trolley jack under 1 corner and lifting the car 3" I could get every thing level in both planes without the faff Evil or Very Mad
FYI I have a short (18") spirit level which I sat on the air box under the bonet and then on the side steps of the car.. you could also run a level across the tailgate Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #408914 11th Oct 2016 11:39pm
Buff Rio
United Kingdom 2009 Range Rover Westminster TDV8 Mariana Black
Good point Miggit, It looks level but never actually checked it with a level. Will run it for a few days then swap again but this time check for level before. So with everything drained out that will come out through the sump plug, What should my target of litres of fluid to get in be ? Its got to be 5 or 6 hasn't it not 3.5 ? 2006 3.0 TD6 Vogue Black - sold
2011 4.4 TDV8 Vogue SE Black - sold
2007 4.2 supercharged Vogue SE Grey - sold
2003 4.4 V8 Vogue green - sold
2009 3.6 TDV8 westminster mariana black 59 plate - current
Post #408944 12th Oct 2016 8:35am
miggit
Err it's a bit more than that Bud, the fill from dry is 9.9 litres and a refill is 6 litres.... so there's 3.9 litres trapped in the torque converter Shocked
The problem with dropping the oil and refilling is the 3.9 litres of old / contaminated / incorrect oil left in the system... the "power flush" method will get 99% of this oil out of the box.... where as dropping the oil and refilling will leave the 3.9 litres or 39% of the old stuff to contaminate the new... and this where you'd need a real maths genius to workout the dilution rate... but suffice it to say, no matter how many times you drop the oil you will still have an element of the old stuff present Shocked
Personally I'd be power flushing with 10 litres of the correct fluid, and then have an extra litre to top it up Thumbs Up
As far as target amount of oil into the box... the same as what you took out (that's what the calibrated drum is for), and then check level on the level at the correct operating temp...... If you've ever owned an old style automatic you'll know just how much the oil expands in the box... "hot and cold" on the dip stick Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #408950 12th Oct 2016 9:07am
IMHO, waste of time measuring what came out, you want the correct amount in there, not someone else's mistake, do it by the book and all will be well.... Thumbs Up Pete
Post #409029 12th Oct 2016 3:11pm
Buff Rio
Cheers Pete
Point taken 2006 3.0 TD6 Vogue Black - sold
Post #409061 12th Oct 2016 7:59pm
miggit
I agree if your dropping it into a bucket and filling it up.... BUT when you power flush it is very important not to run the gearbox dry.... so you pump out 2 litres and fill 2 litres, and so on,. The transmission fluids' first task is to lubricate the pump, without this the pump will wear and not function properly and will have major knock on effects in the rest of the gearbox operation.
So the measuring of what came out is more to make sure that you don't run dry, more than monitoring what's going in.. you can't over fill the gearbox cos your filling it to a level plug / filler, but you can over do the flushing bit Thumbs Up Yesterday I couldn't spell Engineer... Today I are one!
Post #409085 12th Oct 2016 11:24pm
Buff Rio
Update
Drained it out again and put in 5.5 litres. It runs really smooth and changes nicely with not a judder in sight so going to leave it at that for the moment. So it must make a difference having the correct type of fluid. Will do full filter change etc next time
Thanks everyone for your contributions 2006 3.0 TD6 Vogue Black - sold
Post #410662 25th Oct 2016 6:11pm
Starberg
Sweden 2003 Range Rover Vogue 4.4 V8 Java Black
OT but i noticed in your signature that you started with a 2006 ff than a 2011, 2007 and now a 2003. How come? Usually its the other way around that you start with a older model working your way up. Razz L322 Vogue 2003
Post #410670 25th Oct 2016 7:19pm
Buff Rio
Ha Ha, yes I know. Because I was doing quite ok with my business until someone took me for a load of money and financial problems. I lost a lot but really missed my FFRR so scrapped together 5K to get an old one and it rides really nice. Doing ok now so maybe get a newer one soon but enjoying it at the moment. You know bong, ping, check side light bulbe, check side light, check coolant, air suspension inactive, thinking about just blocking out the display Laughing Laughing 2006 3.0 TD6 Vogue Black - sold
Post #410675 25th Oct 2016 8:00pm
I thought it was because you had seen the light and realised how much better the earlier ones are.... Very Happy
Well that's what I keep telling myself.... Rolling Eyes Pete
Post #410693 25th Oct 2016 9:47pm
Starberg
Was hoping for something like that to Hayland Laughing L322 Vogue 2003
Post #410712 26th Oct 2016 5:28am
miggit
Whistle Well I'm sure that he isn't missing the rust Shocked Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #410730 26th Oct 2016 10:30am
Buff Rio
Laughing supercharged was the best, will get another of those I thinks 2006 3.0 TD6 Vogue Black - sold
Post #410737 26th Oct 2016 11:43am
Page 3 of 3 <123
