Home > Technical (L322) > Nearside Screen wiper packed up
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Hello all
Last week the passenger side windscreen wiper packed up. having removed the central air intake box from the engine compartment (surprisingly easy too do), I could see that the arm from the driven arm had detached from the passenger wiper arm. A simple push fit appeared to cure the problem - well at lest for a few days.
Packed up again tonight. Big Cry
Does anyone know if there is a proper bolt fixing (which may have disappeared) or is it that simply a push fit friction fitting that has worn? It looks like the female and male parts are very much an integral part of the arms which could be PITA to change?
I'm gong to look at drilling and bolting if all else fails.
Cheers Gents. 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #409320 14th Oct 2016 6:12pm
Lukie
2002 Range Rover Vogue 4.4 V8 Zambezi Silver
usually when wiper linkage's start playing up sadly it's a complete linkage replacement
Post #409329 14th Oct 2016 8:06pm
In that case it is worth a drilling and bolting attempt Thumbs Up
Is it really that rainy in Worcestershire then? Laughing .
Post #409348 14th Oct 2016 10:38pm
steveball
United Kingdom 2010 Range Rover Vogue SE TDV8 Bournville
I had exactly the same happen to me on my 2002 TD6. I was in the outside late of the M4 doing about 70mph (!) in pouring rain. The passenger wiper stayed in the middle of the screen, being bashed by the driver side wiper which was continuing to run at full speed. After about 20 sec, the driver side wiper blade broke free and went flying over the roof. Not an experience to be repeated.
The linkage is just a push fit and both mine were very worn. I drilled them and put a bolt through with washers and a nylock nut. It solved the problem, but the wiper mech was never quite the same. There was always some play and I really should have replaced the whole thing. From memory, I think mine had done about 150k miles at the time of the failure. Current: 2010 Range Rover L322
Vogue SE, TDV8 3.6, Bournville
Now gone: 2002 Range Rover L322
Vogue, TD6, Giverney Green
Post #409369 15th Oct 2016 8:51am
GraemeC
United Kingdom 2007 Range Rover Vogue SE TDV8 Zermatt Silver
I have had the same thing happen at 70mph on the motorway, managed to move the near side wiped out of the way and continued home. They are simple push fit onto a ball joint. LR do not sell the 50p piece which wears, only a complete new level Noah's with motor for abou £200....
Gravity plays a part, so I just pulled the other end off, reversed it and pushed back on. Must have done 10k miles since with no problem. A windscreen wiper repair clip would work but I've not found one big enough. Will probably drill and bolt my necwhen it eventually fails again.... 2007 Zermatt Silver TDV8 Vogue SE - now sold but was a great car!
Post #409381 15th Oct 2016 11:22am
ajac8
Thanks for the feedback - bolting it is then.
I'm not sure if it is actually possible to release the ball joint to reverse as above - all looks a bit solid to me.
Yes Joe it does rain here - twice so far this year. Once for 3 months and once for 6 months!! Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #409395 15th Oct 2016 2:27pm
^^^ Rolling with laughter .
Post #409412 15th Oct 2016 4:03pm
There's Is a repair option which locks the ball in the socket.
You can get them off of ebay I think looked at it before when some one posted up with a broken wiper linkage. Will see if I can find it.
http://www.fullfatrr.com/forum/topic36054....er+linkage
This is the one I remember, but seems no one got any in the right size. But a fix was achieved by reversing the arm. There is nothing that can't be fixed with a hammer😜😜
Post #409437 15th Oct 2016 9:25pm
ajac8
Thanks NMJ.
Carried out the repair yesterday. 2mm HSS drill bit and some 2mm wire. drill hole - wire through and tie up. copious amounts of copper grease and job done.
it helps that the motion is only side to side and not a full rotation. .
Thumbs Up Thumbs Up 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Gone in order:
03 L322 Oslo Blue
98 P38 Rioja Red
Post #409489 16th Oct 2016 11:52am
Thumbs Up .
Post #409567 16th Oct 2016 10:07pm
