![]() | Home > Maintenance & Mods (L322) > Engine Failsafe Mode Fault......... Fault...!!??! |
| doclees Member Since: 24 Jun 2015 Location: PA Posts: 672
It would be great to test. Most of the RR posts I have read have been from LPG conversion owners but not all. Battery was number 2. Seems to be controversy if you can even get LPG of a quality less than proper. If you can get local consensus from LPG conversion owner where they have had problems and do a couple of tanks there the a couple of tanks of the good stuff. |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8823
Liquefied Petroleum Gas or LPG (also called Autogas) consists mainly of propane, propylene, butane, and butylene in various mixtures. It is produced as a by-product of natural gas processing and petroleum refining. The components of LPG are gases at normal temperatures and pressures. One challenge with LPG is that it can vary widely in composition, leading to variable engine performance and cold starting performance.
Maybe that explains why my gas grill has a mnd of its own.
Right then, it's nothing to do with LPG, got a new tankful from my usual place and it's still doing it...
I looked at a lot of BMW forums regarding this issue. When it isn't a major issue with driveability it ends up being MAF, throttle position sensor or dirty connection to ECU. Is their anything you can do to increase the chance of it getting set off? It seems like a momentary weak signal, like you get with old O2 sensors, sets this off. I know we are not supposed to drive too much with the iidtool in but if you can set these to record if tripped outside its normal values you might see something. |
My IID is non BT so it won't do that...
| UK Marine Member Since: 22 Jul 2016 Location: Durham, County Durham UK Posts: 836
Hey Pete.
I don't recon it's heat related, mines done it twice now in just under three years, then been fine with no input from me to fix it... Can't pinpoint it, not heat/cold related, not wet/dry related.... All sensors working fine... I recon it's a gremlin in the BECM but that's just a theory....
Went out this morning and as expected all faults gone, even though I can't clear them with the IIDtool when they occur. I then took it out again and sure enough after about 20 - 30 mins driving it bongs up again - hdc, eas and trans fail. I must point out that the gearbox isn't really in fail safe as it shifts normally - odd.
I've never had trans fail fault, we probably have different problems... you have checked your voltage, haven't you...?? |
Yes, and one new battery and one new alternator later.................
| All times are GMT |
