Home > Technical (L322) > EPB 2008 FF HSE
Blankone
United Kingdom 2009 Range Rover Vogue 4.2 SC V8 Buckingham Blue
EPB 2008 FF HSE
Morning people,
Need some help with figuring out the issue with EPB I have, I rarely use the EPB but car went for local MOT and failed for parking brake not working, so stripped out fitted new shoes (lining had become unbonded and disappeared?) RAVE states need to set up in mounting position then bedding in procedure so just got a IID Tool and plugged in cleared faults went to set in mounting position and it says "undefined" messed about then got a over temp error on the tool. All I get o the message center is "system unavailable" if I drive and apply the EPB as per bedding in it stops ok but on normal braking only.
Tried the unjam procedure still the same, anyone out there have any similar experiences and can advise to a solution with out going main dealer route as they are damn expensive here.
Cheers and sorry for the long post.
Post #409457 16th Oct 2016 7:16am
I would send Pat at Gap a message, they are very helpful and have probably come across this before... Thumbs Up Pete
-Click here for Thread-
Post #409478 16th Oct 2016 10:59am
Blankone
Quick update, managed to sort it, not sure how but got into the bedding in procedure, 3 times on the pedal, 4 on and 3 off on the switch and 10 stops and it works without faults and passed inspection, happy days!
Post #409501 16th Oct 2016 12:52pm
