![]() | Home > General > L322 - Big Mileage? |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
there is loads of info on here re the differences between the TD6 and the TDv8, and in terms of the drive train it is not just the engine. The gearbox on the tdv8 is a lot more robust than the TD6, though it can have its own problems they are much less frequent. The engine is also pretty robust, though this too can have issues, revolving around blown turbos/hoses, and failing alternators.
Macca Member Since: 04 Oct 2016 Location: Nottinghamshire Posts: 21 ![]() ![]() ![]() |
Ditto above! Get a good one, absolute pleasure, get a "less good one" and deep pockets are needed. Be aware if going diesel may find TD6 is underpowered depends entirely on expectations also model 2006 cross over year, prone to some potential additional gremlins! but also many interchangeable BMW parts that can be a benefit if of course they are needed! D3 TDV6 SE 2006
Sit Member Since: 13 Jan 2010 Location: Bristol Posts: 10 ![]() ![]() |
Thanks gents, Imam working my way through all the threads and info on here - it's certainly extensive!!!
archermav Member Since: 01 Jun 2015 Location: Black Country Posts: 354 ![]() ![]() ![]() |
What would consider to be hefty miles mate?
I believe the crossover was certain vin range circa mid 2005 (MY2006) which had a hybrid of BMW / Jaguar & Ford electronic systems as LR phased out the BMW E39 electrics. If you have access to hook up to JLR diagnostics all gets revealed via its trial and error on comms!
Road Stone Member Since: 08 Mar 2014 Location: Uganda Posts: 227 ![]() ![]() ![]() |
G'day,
rar110 Member Since: 09 Aug 2014 Location: Brisbane, Australia Posts: 1119 ![]() ![]() ![]() |
Gday Jerry
Hi Pete,
pembsRR Member Since: 15 Oct 2012 Location: Wales Posts: 35 ![]() |
Realistically they are expensive and complicated cars, so if something small goes, it will still cost. I had a steering sensor give up earlier this year, which threw out the stability control - to be fair the car was fine and drive able but I had it sorted asap and think it was £400 from my local Indy |
