Home > Technical (L322) > More Battery Problems !?
dan_uk_1984
td6 vogue wrote:
Dan what do you think????? What should i check next?
dan_uk_1984 wrote:
You need to try and find the drain, the easiest way to do this is with one of these gadgets:
http://cgi.ebay.co.uk/Car-Battery-Fuse-Amp...5d242671a1
Dan
Post #40981 5th Dec 2010 7:09pm
td6 vogue
United Kingdom 2004 Range Rover Vogue Td6 Java Black
Thanks Dan . I knew you would say that! I have one on order!
Post #40997 5th Dec 2010 8:20pm
dan_uk_1984
In the mean time you can start pulling fuses to see when the drain stops?
Post #41003 5th Dec 2010 8:30pm
td6 vogue
Fuse 49 is my problem . Pulled this and the drain stops. This is for navi system,on board comp, on board monitor,audio system. What could it be? Trip to LRMD i think!
Post #41998 12th Dec 2010 5:16pm
dan_uk_1984
OK, now you'd found that you can elliminate specific components... First thing to check though, leave the tailgate open for 10 minutes with the access pannel for the nav drive off. Make sure that after 5 minutes the reg light goes out.
Reason I say leave the tailgate open is that if you open any door in the car it will wake the nav up.
Try this and report back...
Dan
Post #42004 12th Dec 2010 5:40pm
td6 vogue
Thanks Dan, will do.
Post #42007 12th Dec 2010 5:46pm
td6 vogue
OK. Dan i sat in the boot for ten minutes, put the fuse back in and then waited. The red power light on the navi did not go off.
Post #42016 12th Dec 2010 6:22pm
dan_uk_1984
OK, as long as you didn't touch any other door (inc the lower tailgate release button) and the light stayed on then I would say your problem is there.
I may be wrong, but I'm sure I read that a corrupt firmware can stop the nav unit from going to sleep...
Does the light go off ever? ie if you check it after 30 mins - you could fold the parcel shelf back, remove the access panel and then peer through the window to see if the light goes out.
Dan
Post #42024 12th Dec 2010 7:30pm
td6 vogue
OK will check it again tomorrow. Thanks again Dan.
Post #42031 12th Dec 2010 7:48pm
dan_uk_1984
You can unplug it easily enough to see if your drain stops. But you've got to be careful doing that when it's not shut down. Again I'd probably leave it five mins before unplugging it to ensure 100% that its stopped writing to memory.
Post #42034 12th Dec 2010 7:56pm
td6 vogue
IF i pull the fuse first then unplug it,it will def be shut down !??
Post #42043 12th Dec 2010 8:27pm
dan_uk_1984
Should be, but wait 5 mins after opening the door before pulling the fuse. Its opening the doors which cause it to wake up...
Post #42067 12th Dec 2010 9:55pm
td6 vogue
Now taken the nav box out and put the fuse back and put the ctek on the car to see if its that. That fuse is the only one that sparks a little when going back.
Post #42164 13th Dec 2010 2:56pm
td6 vogue
update. With sat nav box out ,Ctek has charged battery already,so will see if i can get the box looked at!
Post #42170 13th Dec 2010 3:51pm
