![]() | Home > Technical (L322) > rear wiper washer |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6825 ![]() ![]() ![]() |
Take a look here - http://www.fullfatrr.com/forum/topic9924.html |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
That's perfect...thanks! |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
That sounds even better! Ordered some seals earlier from amazon.couple of quid delivered..will pick up some epoxy resin Friday and that's my Saturday task on the full fat..cheers again buddy |
This is the stuff that I used http://www.toolstation.com/shop/Adhesives+...sin/p29905
Just picked up the same stuff |
Miggit...it worked a treat buddy! Did everything you advised and the epoxy did the trick! Thanks again guys |
Your welcome Bud |
Earl of Ankh Member Since: 25 Sep 2016 Location: Devon Posts: 1 ![]() ![]() ![]() |
Having read this post and having the same issues myself I decided to give it a go. Washer jets now cleaned and working and the wiper arm lubricated and sitting nicely on the rear window.
stu_007 Member Since: 25 Jun 2016 Location: Cardiff Posts: 177 ![]() ![]() |
I was going to give this a go but ended up buying a complete new motor. "YYS" G4 FFRR
^ I think you wasted your money |
![]() ![]() ![]() ![]() I have always used the philosophy that you can't break it anymore than broken, but you might be able to fix it and save a fortune ![]() ![]() ![]() Inventor of the 'Guide-o-Matic automatic wheel alignment tool' Former long term L322 owner, Up/Down graded to a Classic Tractor! |
builder1966 Member Since: 23 Aug 2016 Location: ashingdon Posts: 299 ![]() ![]() ![]() |
did away with mine going though the motor and put dual sprays on mine and wow has made a great difference can actually see from back window when driving down really dusty sites |
