Home > Wheels & Tyres > New tyres
chefkenmore
Scotland 2014 Range Rover Vogue SE SDV8 Loire Blue
New tyres
So two new tyres on the front on Monday! Don't ask!
Suspension problem on the way home yesterday! Car down at the front but up at the back!
Call the AA who take it to my Indy,
New front near side sensor, car on test run and blows a hole in the rear airbag!!
Not a happy bunny 2014 vogue se
Post #410134 21st Oct 2016 4:41pm
miggit
D'OH! sounds like you need to fill the system with a puncture sealer Wink
Anyway tyres.. round black things.. one in each corner.. what else do you want to know Wink Yesterday I couldn't spell Engineer... Today I are one!
Post #410142 21st Oct 2016 5:01pm
They always do that... lots of parts wear to a point and then get tipped over when something unusual happens...
Change two tyres and the sensors have to move more than a few mm and if they were near the end of their life it tips them over the edge... rear bag, sat doing not a lot for ages, then gets extended when front drops and the additional strain on it tips it over the edge....
Ask an MOT guy how many flexible hoses he has had blow on the brake rollers... work fine at normal braking, testing it they try to lock the wheels, up's the pressure and finds the weak spot....
No consolation but hopefully that will be it now.... Thumbs Up Pete
Post #410143 21st Oct 2016 5:34pm
pembsRR
Sorry to ask a daft question, but aren't you meant to change all 4 at once on 4wd? I've always done this as I thought the difference between rolling circumference could cause a problem
Post #410346 23rd Oct 2016 7:43am
miggit
It's only the high performance 4x4 that appear to be effected.. Whistle reckon that limited slip diffs do have their disadvantages Rolling Eyes
There are some cars out there that require you keep the tyres with in 5% of each other, and these are the ones that end in tears come tyre time... Because the Range Rover has open diffs it will cope with a slight variation in tyres, although it would be an issue if you had different sizes across the axles or MT's at one end and Road tyres on the other (10+mm difference in diameter) Shocked Yesterday I couldn't spell Engineer... Today I are one!
Post #410354 23rd Oct 2016 9:25am
