![]() | Home > Technical (L322) > 4.4 tdv8 12MY reluctance to start |
JST Member Since: 12 Dec 2013 Location: Somerset Posts: 502 ![]() ![]() ![]() |
anyone else experience this:
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3269 ![]() ![]() ![]() |
Starter solenoid needing to be replaced/repaired? John
or SM are my thoughts but keep wondering if it isint something else not allowing it to go! Cheers
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35801 ![]() ![]() |
was the battery fitted before or after this problem.....if before are all the battery connections tight.. ... - .- -.
i had this problem with new vehicle as it came so on thrid day replaced the battery, no change Cheers
nino_nino Member Since: 29 Mar 2015 Location: pocitelj Posts: 690 ![]() ![]() ![]() |
I had similar problem with my Td5 and it was starter solenoid. You may tray cleaning el.connection at the starter. |
Stuart Member Since: 06 Feb 2011 Location: Cambridge Posts: 85 ![]() ![]() ![]() |
Hi James
its going in tue to be looked at by dealer.
Pfazz Member Since: 07 Apr 2012 Location: Stalybridge, Cheshire. Posts: 507 ![]() ![]() |
James, I had this same problem on my 2011 tdv8 when I was a year old. Dealer fitted a ew starter motor at that time and I had no further problems for the next 2 years which I had the car. I believe it is a known fault and has been raised on here in the past. Agueroooooooooo. 93-20
thats nice to hear, well sort of! i am hoping that it will replicate the fault at the dealers and they can find the problem if ^^is the case then it should be easier to convince them there is a problem if it doesn't actually replicate it when they have it.
Philip Member Since: 05 Jan 2010 Location: UK Posts: 2621 ![]() ![]() |
Likewise, a new starter under warranty. Annoying when it won't start when you're about to drive off the Eurotunnel though. |
heppsen Member Since: 14 Feb 2012 Location: germany Posts: 170 ![]() ![]() ![]() |
Precisely the same problem with m 2012 TDV8 and wife brought it into the dealer yesterday.
mine goes in tomorrow! Cheers
Update: new starter motor. Apparently fully covered labour and parts money wise.
