![]() | Home > Technical (L322) > christmas tree faults |
From your description I would look at the very basic things first. Those faults might be sporadic but the general conditions you describe could be something as simple as a bad earth. That "Christmas Tree" scenario is normally because the voltage supplying the various ECUs drops low and causes one or more of the ECUs to reset.
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
Generally when the transfer box joins in with HDC faults it's power related... normally lack of, caused by duff battery, so a rotten earth connection could be the source..... And I thought that those faults had died with the Defender, |
alangrig Member Since: 03 Jan 2016 Location: Riga Posts: 26 ![]() ![]() |
Thank you very much, appreciate. BTW, battery is newly fitted last winter and occasionally on start the message pops up on screen: reactivated suspension. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8776 ![]() ![]() ![]() |
as above, the easiest place to start is the battery terminals. Then move to earths.
Thank you! |
The issue is solved: the problem was related in high pressure pump PCV Valve. Indie flushed it away with brake cleaner several times. For the last 3 months no issues so far.
L322Dino Member Since: 16 Apr 2017 Location: Ligne de Maginot Posts: 5 ![]() ![]() ![]() |
Photos the pcv valve ? |
Dear All,
