Home > Technical (L322) > Strange "Pwarp" noise from brakes
jonny142
United Kingdom 2004 Range Rover Vogue 4.4 V8 Buckingham Blue
Hi Guys,
Not sure if anyone can help, I have the occasional noise from my brakes, it almost sounds like a loud fart..
I had new disks and pads fitted 6 months / 5k ago... brakes have been ok, until the last couple of weeks.. I have had the garage check them and no faults founds..... but I still get the occaisional noise.
The brakes work perfectly... but the noise is staring to P155 me off!!!!!!
Any ideas Chaps ? Big Cry 4.4 V8 Vogue Adriatic - Cream leather
Post #4065 21st Mar 2009 8:34pm
what circumstances do you get the noise? Is it when manoeuvering about at low speeds? Discovery 4 HSE
Post #4075 22nd Mar 2009 11:21pm
jonny142
Hi RR,
It usually happens when braking during normal driving conditions, and is intermittant
Cheers 4.4 V8 Vogue Adriatic - Cream leather
Post #4106 23rd Mar 2009 3:14pm
I get that sometimes as well , i just put it down to the pads closing against the Disc's thats basically all it is , wouldn't worry to much about it......... Thumbs Up
Post #4107 23rd Mar 2009 3:20pm
jonny142
Someone has suggested "anti squeel sheilds" never heard of them myself 4.4 V8 Vogue Adriatic - Cream leather
Post #4108 23rd Mar 2009 3:24pm
Heard of "shields" on your Family Fords,Vauxhalls, and like but not on the FFRR.
I mostly get it when i have not fully depressed the brake pedal and you would think by the sound as if there was no pads at all , and when moving off when i release the brake pedal.But on very few occasions .
ITS NOT A FAULT WITH THE CAR ( LAZY USE OF THE BRAKE PEDAL ) Thumbs Up
Post #4109 23rd Mar 2009 3:30pm
dantheman
Try taking your pads out, and coating the back (metal side) of them in copperslip - a sort of high temperature anti-corrosion compound - or grease which is commonly used in this application.
Just make sure you don't paint it onto the friction linings... Whistle
Hope this helps,
Dan. Thumbs Up
Post #4121 23rd Mar 2009 6:24pm
Dan if your brakes squeal, what is that a symptom of and how can it be remedied? My front ones squeal now and then at low speed in traffic. Discovery 4 HSE
Post #4123 23rd Mar 2009 7:54pm
dantheman
RRUK - Remedy wise, although brake squeal can be more of an annoyance than a safety issue there are several possible fixes:
Strip & clean brakes coating with copperslip as above; renew damaged/worn anti rattle springs or clips; tighten/replace loose brake components etc. The list could go on forever - cheap non OEM brake components can also be a culprit.
Take a look at the following link, which does a pretty good job of going further into brake squeal:
http://www.aa1car.com/library/2004/bf80426.htm
Hope this explains it, and is of help.
Dan. Thumbs Up
Post #4136 24th Mar 2009 2:48am
