![]() | Home > Technical (L322) > stall speed: what should be OK? |
Stacker Member Since: 04 May 2016 Location: Theale, Reading Posts: 479 ![]() ![]() ![]() |
What's this in aid of? I would have thought it puts unnecessary strain on already weak parts e.g. Gearbox and torque converter? |
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3661 ![]() ![]() |
^^time bomb and ticking come to mind |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8610 ![]() ![]() ![]() |
Checking the stall speed is a recognised way of detecting faults with a TC, in a well running box that is up to temp it does not harm the box to test it once or twice.
Not sure where my negativity regarding my TD6 comes from, it never breaks |
Pete I looked in to a super duper all singing and dancing H/D torque converter... and by the time I had paid for it and the shipping I could have had the gearbox rebuilt |
Rangie4fun Member Since: 26 Mar 2014 Location: Home sweet home Posts: 167 ![]() ![]() ![]() |
thnx for your replies |
Yup |
I agree with the design and just thought this was the cause of the problem, but then I tried it on a flat surface and the problem is exact the same |
Low oil?
indeed the design is not one of the best i guess... |
RRPhil knows enough about the GM5L40E gearbox to specialise in the ZF box instead |
My gearbox re-builder wanted to exclude a valve block failure so today he installed a new one. It didn't cure the problem |
I wonder if it could be pressure related... too much rather than not enough... like the pressure relief valve keeps on blowing... bit like a pressure washer with a semi-blocked nozzle |
