Home > Technical (L322) > TDI6 RR Water system full of oil
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
Hi, a riend has asked me to look at his RR its a TDI6 about 2003, the whole water system is full of engine oil to the point of forcing it out of the reservoir and obviously no oil on the stick but car runs like a watch, my first thoughts are ( I dont work on diesels) has this engine got a water to oil cooler and has it split inside? any thoughts? One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #411120 28th Oct 2016 2:05pm
The td6 has an oil to engine coolant heat exchanger just behind the oil filter housing and a transmission fluid to engine coolant on the lower side of the engine block near the front.
Both of these coolers are plate heat exchangers and can be prone to internal corrosion allowing mixing of the fluids if they fail.
Post #411165 28th Oct 2016 7:10pm
JohnnyDangerous
Exactly my first thought, just needed it confirming, many thanks. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #411179 28th Oct 2016 8:58pm
miggit
Can you make out what type of oil it is? only if its the gearbox you might have a few problems with contamination Rolling Eyes Yesterday I couldn't spell Engineer... Today I are one!
Post #411206 29th Oct 2016 12:24am
JohnnyDangerous
Its engine oil. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #411222 29th Oct 2016 7:09am
