Home > Technical (L322) > Rear spoiler differences 02-09 and 10-12
GraemeS
Australia
The spoilers have different part numbers even for 02-09 versions suitable for a reversing camera. I want to experiment cutting holes in the top and bottom trying to direct air down the rear window but wont be cutting mine. However a cheap early version is of no use if it wont fit.
Is the difference due to different stop-light dimensions?
Will an early one mount on a later vehicle, even if the later stop-light isn't a direct fit?
Thanks
Post #411219 29th Oct 2016 3:29am
Mr Tee
Scotland 2019 Range Rover SVAutobiography 5.0 SC V8 Waitomo Grey
Think I have the old stop light from my 2002, I'll have a look later.
Post #411242 29th Oct 2016 10:55am
GraemeS
Australia
Thanks.
Post #411326 29th Oct 2016 8:22pm
Mr Tee
Sorry for huge delay, they look identical
Post #412353 6th Nov 2016 12:16pm
GraemeS
Australia
Thanks Mr Tee.
The cheap enough earlier spoiler is not nearby so I still have to consider the cost of getting it, either the freight or the time and fuel. I'm not very hopeful that I can cause a sufficient reduction in dust accumulation under the top of the upper tailgate and along the hip at the bottom edge of the glass but would like to try.
Post #412416 6th Nov 2016 8:29pm
vaz
United Kingdom 2007 Range Rover Vogue TDV8 Java Black
There are three differences to the spoiler.
The early ones, 2002-2005/06, no camera fitted (as far as I know).
2005/06-2009 fitted with camera.
2009 onwards, also fitted with camera, these are a different camera to the 2005/06-2009 and are mounted in a different place around 30-40mm (1-1/8" to 1-9/16") further to the right of the hi level brake light unit.
Mounting the spoiler to the door frame as far as I can tell uses the same slide on mounts and three 6mm bolts to secure it.
Unfortunately the 2009 onwards spoiler went to the tip a couple of weeks ago, the outer skin was badly damaged.
Steve. 1968 Series IIA Pastel Green, nearly there project
Post #412698 8th Nov 2016 9:36pm
