![]() | Home > In Car Electronics (L322) > Alpine EZi-DAB Installation |
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6819 ![]() ![]() ![]() |
When I installed mine, I ran a phono cable to the rear entertainment connector in the back. Works a treat and is pretty unobtrusive.
Mikey32 Member Since: 10 Jun 2016 Location: Oxford Posts: 9 ![]() ![]() ![]() |
Hi
That's where I stuck mine initially but when I stuck a BlackVue camera next to the rear view mirror, it killed the DAB signal, so just be aware. I ended up putting a new antenna on the rear side window and all was well again.
Hi.
Eirik34 Member Since: 16 Dec 2014 Location: Norway Posts: 443 ![]() ![]() |
Hi Mikey, I need to upgrade to a DAB+ in our FF07 as well (due to the fact that national radio stations in Norway will be moved to DAB+ nest year - the FM signals shut down), and of course ideally would have preferred to install an integrated MOST DAB device, but no such device exist for the 07 Vogue, I think.
Will it be possible to use the MOST-AUX device from NAV-TV
