![]() | Home > Technical (L322) > Abs light and soft brake pedal. |
Weejock Member Since: 31 Dec 2011 Location: UK Posts: 419 ![]() ![]() |
Sounds like air in the system somewhere as air is compressible (hence soft pedal) where as fluid is not. It can also effect the ABS operation.
alanm_3 Member Since: 19 Feb 2011 Location: my House, unless I’m not at home, in which case I’m somewhere else. Posts: 6825 ![]() ![]() ![]() |
Do you live in a "wet" state that has lots af rain? Your brake pipes could be corroded and leaking. Have you seen any drips of brake fluid at all? Got - 2017 SDV8 Autobiography in Loire Blue
StewD Member Since: 22 Apr 2016 Location: Glasgow Posts: 129 ![]() ![]() ![]() |
Sounds like you changed the pads hoping to cure a soft brake pedal...? If I read your post correctly.... System needs bled which is a simple job. Current: Supercharged 06 FFRR in Java Black
umitbat Member Since: 06 Jan 2010 Location: Space Posts: 433 ![]() ![]() ![]() |
Thanks for answers.
