Home > General > Petrol in a diesel - Eejit!!
Rosco
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
So, late for a meeting this morning and needed a splash and dash.... yes for the first time in 35 years of driving I misfuelled. On the motorway and a weird shuddering, gearbox was my initial thought as after 130K miles I am waiting for it and wake up in sweats about the bloody thing, anyway, I slowly realised that I had put £20 of petrol in . SO long story short, I brimmed it with diesel and have done about 100 miles since with apparently no issues. am I OK or should I just hand myself in now!! It had about 5 gallons in it when I did the deed, cheers Very Happy
Post #412180 4th Nov 2016 9:33pm
johnboyairey
I've used a similar mix, on a diesel van, and it drove fine. The only real problem I was told, is that the solvent action of the petrol, can mean that the pump possibly could be damaged, as the oiling of the diesel fuel is self lubricating.
Put it down to a senior moment. And spend the cash you saved, from not having it drained. I think it's about £200.
Post #412181 4th Nov 2016 9:40pm
I'm far from an expert, but I'd run it - but keep topping up the tank with diesel to further dilute
Post #412184 4th Nov 2016 9:45pm
Mikey
The Td6 is more tolerant of a splash of petrol than the V6/8's, but keep it topped up with diesel just to help dilute it as much a spare possible
If nothing else, it works as an injector cleaner, and stops the diesel from waxing Whistle
Post #412187 4th Nov 2016 10:00pm
Rosco
Thanks Chaps, made a call to a friend who is a dealer and he reckoned I would be OK, hope this is not a senior moment as I am only 22 (in my head) Rolling with laughter
Post #412188 4th Nov 2016 10:01pm
you probably cleaned the injectors doing that ...top tip Laughing Wink ... - .- -.
Post #412200 4th Nov 2016 10:45pm
Rangeyman
Like the others say,it is not a problem with that amount
Post #412201 4th Nov 2016 10:45pm
Rosco
Thats what I had heard Stan but obviously not something to try, thanks for the replies guys, Bow down
Post #412203 4th Nov 2016 10:52pm
janderson41
I would also put a bottle of 2so into a full tank of diesel.
Use cheapest mineral 2so from Morrisons at £2. For a bottle
If you are not sure about using 2so just google " 2so in diesel"
There is enough info to keep reading for a month.
I always put 2so in by proportion each time I top up
Cheers
Jim A
Post #412211 5th Nov 2016 12:05am
Mikey
As do I Thumbs Up
Post #412216 5th Nov 2016 8:31am
nino_nino
me to Thumbs Up
Post #412224 5th Nov 2016 12:11pm
JohnJ
Italy 2011 Range Rover Vogue 4.4 V8 Santorini Black
I did it two times Very Happy and never had any issues... just some engine hiccups when driving, of course dilution is the way to go! 2011 Vogue 4.4 Santorini black
prior:
2010 Vogue 4.4 Buckingham blue
2007 Vogue 3.6 TDV8, Stornoway grey remap
___________________________
POSSUNT QUIA POSSE VIDENTUR
Post #412494 7th Nov 2016 10:32am
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Sounds like you may have got away with it.
Unsure the age of yours?. However, The newer models suffer more & require full drain & replacement of parts depending if the engine has been run & distance traveled etc (warranty issues).
Post #412594 7th Nov 2016 9:36pm
2004 TD6 - if you hover over the little car symbol on the left of the posts, it tells you Thumbs Up
Post #412604 7th Nov 2016 10:43pm
Bugcos
Did this in a lorry a few years back. Looked up an had put 105 litres of petrol in Embarassed Embarassed . Went in and paid. Then put 550 litres of dev in. It smoked a bit but I got away with it, the boss did find out though, it was me Embarassed
Post #413423 13th Nov 2016 9:00pm
