Home > General (L405) > Running wiring through to inside of the car from engine bay.
jettec
Australia 2013 Range Rover Autobiography TDV8 Fuji White
Hi, does anyone know of a spot to run wiring from the engine bay through to the inside of the car ?
As I am putting new Led spot lights on the front of the car.
I have not seen anywhere in the engine bay where wiring goes through to the inside of the car.
Post #412377 6th Nov 2016 4:36pm
Do the flip top bonnet thing, then under the brake fluid reservoir you will see a big rubber grommet with loads of wires going into the cab behind the steering wheel...
There is one the other side behind the battery but not as easy to get to...
Thumbs Up Thumbs Up Pete
-Click here for Thread-
Post #412380 6th Nov 2016 5:22pm
as Pete says, thats if yours has the same config as the L322..
stick a screwdriver to the side of the wires through the grommet and pass the wire through the hole.. ... - .- -.
Post #412381 6th Nov 2016 5:37pm
Sorry, didn't see it was a 405.... I expect there is something similar as the 322... Thumbs Up Pete
Post #412391 6th Nov 2016 6:39pm
jettec
Hi guys thanks for trying to help me !
I removed R/H side cover over brake fluid tank and brake booster, i could see the wiring, however it disappears down towards the centre of the car under the steering column , I think going under the steering from inside the car you would see this wiring coming through the panel in the car is easy to remove. But I think you would need wire to feed through from inside then try and grab it from brake booster area, then attach electrical wiring for the Led lights to this lead wire you fed through and pull through led light wiring from the inside of the car to the engine bay area.
I dont think this would be easy to do but it could be done.
So I when for the remote control option for the Led lights, and ran the power wiring for these lights from off the engine bay jump start terminals.
The negative terminal just unscrews and placed the wiring connector under it. Then the positive terminal I just unscrewed the box it was in on one side and the other side of the box is held down with a push in clip that with screw driver leaver it just pops out of the hole, then it is an easy job to attach the positive power wire under the nut that holds the positive jump start terminal.
Then it just routing the Led wiring to the front of the car for the Led lights and tying up all the wiring under the bonnet.
So now I just push the remote and hey presto they work
Post #412487 7th Nov 2016 9:18am
