Home > Technical (L322) > Heated Steering Wheel
Highroller
United Kingdom 2005 Range Rover Vogue SE 4.4 V8 Java Black
Hi all, Just a quick query. Not ever having the luxury of a heated steering wheel on my previous vehicles, it's a joy now the climate has changed.
However, although it works, it only heats in the 10 - 2 & 20 - 5 positions. Is this correct or is it, as I feel not working to its full potential?. Whistle
Post #412587 7th Nov 2016 8:44pm
Paddyc
Northern Ireland 2010 Range Rover Vogue SE TDV8 Santorini Black
Hi I've a my2010 tdv8 vogue se - and steering wheel is warm all the way round - definitely warmest at the point you mention but warm all the way around the steering wheel
Post #412595 7th Nov 2016 9:41pm
pembsRR
Likewise warm around - 2010 vogue se
Post #412597 7th Nov 2016 9:48pm
Yep, should be warm all over... easy to change and Powerful UK do an exchange one for £107
http://www.powerfuluk.com/vehicles/range-r...overs.html
Makes your FF feel like new as well as the leather feels so new... Thumbs Up Pete
-Click here for Thread-
Post #412598 7th Nov 2016 10:08pm
3528cc
United Kingdom 2008 Range Rover Autobiography 4.2 SC V8 Buckingham Blue
Mines is warm all the way round, but has 2 warmer zones @ 3-4 o clock/8-9 o clock positions Regards
Royston
2008 4.2 Supercharged Autobiography
1994 Classic Vogue SE
1999 Rover BRM
1987 Rover Vitesse Twin Plenum
Post #412599 7th Nov 2016 10:17pm
Highroller
Thanks Guys, Looks like I'll be replacing mine at some time then. Big Cry
Post #412601 7th Nov 2016 10:28pm
supershuttle
Yep mine has some spots hotter than others, so they seem to heat up first but eventually it all get nice and warm still with some hot spots. Geoff
Post #412625 8th Nov 2016 8:56am
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Hi Haylands, I was going to start a new thread as the heated wheel on my 2003 TD6 has never worked, the light illuminates for a split second then goes out again, and no heat but I found this thread, so thought I'd jump in too Embarassed (hope thats OK)
The exchange from Powerful UK, is that all that's needed please? Just a straightforward swap?
Post #418477 18th Dec 2016 3:57pm
Yep, send the old one back in the box the new one came in, you have to pay a £50 deposit... they refund it once they get yours....
Check this is the right one for yours, they also do them with the silver spokes...
Removing the airbag takes a bit of fiddling, you have to get the removal tool (a thin screwdriver with the end ground flat, which they supply with it) in just the correct alignment, takes a bit of practice but not too bad, then you need some torx drives to remove the spokes etc...
Watch the video.... Thumbs Up Pete
Post #418481 18th Dec 2016 4:06pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
ive got the half wood, half leather wheel and mine eventually gets warm all the way round too but does start off with warmer spot.However to the guys that are having the 'hot' spots by any chance do you also have the half wood, half leather wheels?
Matt Current
2012 Range Rover 5.0L SC Ultimate Edition
2012 Range Rover 4.4L TDV8 Autobiography
2010 Range Rover 3.6L TDV8 Autobiography
2003 Range Rover 4.4L V8 Bespoke Vehicle
Inventor of the retro fit paddle shift and many other modifications.
Creator of the custom 2010+ RR MK4 splash screen.
Creator of the Range Rover CarPC and lots more!
Founder of Range Rover Owner
rangeroverowner.com | Facebook.com/RangeRoverOwner | Latest Videos âžž YouTube.com/RangeRoverOwner
Post #418511 18th Dec 2016 7:03pm
