![]() | Home > Technical (L322) > Heated Seat Problem - 2007 TDV8 Vogue SE |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35871
that first code is an airbag error.. ... - .- -.
| dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724
Spoke to IID but they weren't able to identify which part. Very helpful and suggested the heater Any thoughts would be gratefully received 2015 4.4 AB
Hi all, just for anyone else with an SE L322 with the heated / cooled seats. My drivers has never worked and it turned out to be part number HHK500060. This is the blower motor for the heated part of the seat. The motor is fine but there is a 90 degree angle piece of abs / plastic that carries the air from the motor / fan to the seat. The angled piece rests against a seat spar that if you push against the seat back hard as you sit in the seat , the part can crack and the air can escape causing the motor / fan to stop because its not getting the reading it expects
also thanks to Axle on this forum, who replied to a PM very promptly and with good advice re this problem 2015 4.4 AB
Finally a heated seat. As above new part arrived from Germany and my indie removed the drivers seat , removed the back of the seat and three screws later and a connector block and the damaged part was removed. , the new unit went straight in and panel on , seat back in and hey presto , heated seat.
| Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156
I think I may have the same problem.
Seat needs to come out to replace but if you remove the armrest you can pull back the seat back cover to see if that's the issue Taking the seat out is easy enough 2015 4.4 AB
| dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1414
I had the same two codes plus one for the seat switch lost comms
| AB54FLY Member Since: 18 Jan 2015 Location: Manchester Posts: 3
+1 for the split pipe.
| RJDS Member Since: 17 Dec 2016 Location: North Wales Posts: 49
I have cooling but no heating on the drivers seat. you can hear the fan start when you set it to heating, but then it shuts down within a few seconds. Does it use the same fan unit and sensor for both? If so I guess it must be the control module and not broken pipework in the seat? |
