![]() | Home > Technical (L322) > Time from low to full ride height ? |
alistairh Member Since: 17 Sep 2016 Location: edinburgh Posts: 801 ![]() ![]() ![]() |
Mines takes about 10secs to get from access to normal height..then it can take between 30/45 secs to properly reach off road height...i find if I switch between different heights quickly it slows....must need time to build up pressure in the air reservoir |
dolph34 Member Since: 14 Sep 2015 Location: Kildare Posts: 1724 ![]() ![]() ![]() |
25 secs 2015 4.4 AB
miggit Member Since: 12 Jul 2014 Location: Milton Keynes Posts: 3666 ![]() ![]() |
With the car in High mode turn off the engine and have a listen by each wheel.. if you've a leak then you'll hear it.. I suspect that it's just an older compressor.. but I will say that the ffrr (early ones) do take their time to finalise the height setting.. they take a few seconds to get within a few mm of the final height and then take forever adjusting it |
b348xyx Member Since: 29 Sep 2016 Location: Kent Posts: 319 ![]() ![]() ![]() |
I had this issue when I first got my Range, was the original compressor. Replaced and was a lot faster raising the car up after and less noisy.
Mulcher Member Since: 08 Aug 2016 Location: Shropshire Posts: 240 ![]() ![]() ![]() |
I think if your car was being too slow to change ride height you'd see the "Vehicle is raising slowly" message on the dash display. 2006MY 4.2 SC
Stormin Member Since: 22 Feb 2012 Location: West Yorkshire Posts: 266 ![]() ![]() |
There's also an air tank in the off/side sill, mine had a piece of wood stuck in it letting all the air out Three things in a blokes life his dog,his car and a Cornish pasty,nothing else matters.
